My washer fills ok then agitates and stops just before the next cycle of rinse/spin, it doesn't spin or drain. The tab that the prong pushes down on the lid switch sometimes doesn't return to its original position when I open the lid. I've tried holding the tab down on the lid switch to see if the tub would spin and it didn't spin. I have tried replacing the timer and still had the same problem.
