My washer is showing a code symbol of Hr. My manual says it is Heater Control problem. Can you tell me which part needs to be replaced. We think it might be the heating kit. What do you advice? Thank you.
According to the Tech sheet (on the back of the washer) the "Hr" error code means "Heater relay failure" and the suggested correction is to replace the machine control board.
If you need the correct part number, post the serial number of the washer.
