rob-o
#1 Posted : Monday, December 27, 2010 7:01:58 AM(UTC)
rob-o
maytag direct drive washer it will agitate but want spin
Joe / APP Team
#2 Posted : Tuesday, December 28, 2010 8:45:45 AM(UTC)
Joe / APP Team
Rob,
You supplied a wrong model number(it's a microwave)
But, I was able to understand, and found the correct number(MTW5700TQ),
I take for granted the motor does run in the spin cycle, since the washer does agitate ?
Every thing else works and there are no strange noises ?
I'm making a guess here, but you most likely have a problem in the Clutch assembly.
Part number: AP3094537
With a bit more information we can be more accurate, but here is an excerpt from our repair forum, to help you diagnose and determine what else could be wrong, and access and repair to the clutch assembly, if needed.
http://forum.appliancepartspros...-washer-brake-shoes.html
If the motor does not run in the spin cycle,
You may also have a bad lid switch, if the switch circuit is bad, it will allow the machine to fill and agitate, but won't let it spin,
Part number: AP3180933
Good Luck,
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Maytag Washer shaking - badly (Washer Repair)
by chansman94 1/12/2023 6:47:51 AM(UTC)
Maytag Washer Unbalanced After Tub Bearing & Seal Replacement (Washer Repair)
by Guest 12/26/2022 7:20:26 PM(UTC)
Maytag washer agitates instead of spins (Washer Repair)
by Guest 12/10/2022 11:31:05 AM(UTC)
The pulley on the bottom of my Maytag washer motor has broken. (Washer Repair)
by Guest 9/18/2022 9:05:55 AM(UTC)
