Discuss
Fridgidaire Washer not spinning
 in
Washer Repair
The washer motor works to run the washer. The drain pump is draining out the water. However, the drum does
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fridgidaire Washer not spinning
  #1 (permalink)
Old 10-09-2007, 10:10 AM
sprout69 sprout69 is offline
Junior Member
sprout69 is on a distinguished road
Default Fridgidaire Washer not spinning
Model Number: LTF2940ES0   Brand: Frigidaire   Age: 1 - 5 years
The washer motor works to run the washer. The drain pump is draining out the water. However, the drum does not spin when it is time to spin and drain.
Related Models
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
Whirlpool LVA5565W0
Whirlpool LVA5565W1
Whirlpool LVA6300W0
Whirlpool LVA6304W0
Whirlpool LVA6305W0
Whirlpool LVA6309W0
  #2 (permalink)
Old 10-11-2007, 03:31 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Does the main motor run in spin??
__________________
  #3 (permalink)
Old 10-11-2007, 10:18 AM
Junior Member
Default
no, the motor does not work in spin mode
  #4 (permalink)
Old 10-11-2007, 12:08 PM
Senior Expert
APP Volunteer
Default
Check your lid switch, probably broken.
__________________
  #5 (permalink)
Old 10-11-2007, 02:46 PM
Junior Member
Default
There is no lid. It is a front loader. Also, the washer agitates, so I wouldn't think that it would be the lid or door switch. But that's why I'm asking you.
  #6 (permalink)
Old 10-11-2007, 05:39 PM
Senior Expert
APP Volunteer
Default
You are fortunate, Frigidaire has very good diagnostics sheet behind the kick panel on the left side. Follow the chain diagram for no spin, dispenser switch, door latch and timer are in the chain.
__________________
  #7 (permalink)
Old 10-22-2007, 05:58 AM
twood twood is offline
Junior Member
twood is on a distinguished road
Default Same Problem
Front load washer, runs fine until it gets to the spin cycle. The washer then makes a loud noise and does not spin. The timer then cycles very slowly, each minute on the timer takes about ten minutes.
If you start the washer from the beginning, it works until you get to spin.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridgidaire Gallery Glass Cooktop-LARGE CHUNK CAME OUT Kiki Oven Repair (including Ranges and Cooktops) 5 10-05-2007 10:34 AM
Fridgidaire Dryer wont heat Hozer Dryer Repair 8 09-11-2007 03:45 AM
washer timer / not spinning pbush412 Washer Repair 0 09-05-2007 11:32 PM
washer stopped spinning leagleson Washer Repair 0 09-04-2007 11:18 AM
