Mike Samples
#1 Posted : Thursday, December 23, 2010 5:39:02 PM(UTC)
Mike Samples
My cold water valve is not getting power. What part do I need to fix that. The valve is brand new. Do I need a new electrical panel?
#2 Posted : Friday, December 24, 2010 4:14:59 AM(UTC)
Here are yiour parts
Replacement parts for MAYTAG MAV6000AWW WASHER, ATLANTIS | AppliancePartsPros.com
Here is a manual that covers your unit. I think you have the analogue temperature control board.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/ec2a315861edab6e8525729c005736f0/$FILE/Maytag_Atlantis_III.pdf
How do you know that the valve is not getting power?
Have you measured it with meter?
Will the it run the cold when in a rinse cycle?
The way I read the timing chart and wiring diagram Page 10-5 on H-C, W-C and C-C settings the cold valve gets power through the timer not the temperature control board.
So if it does run on the rinse I would put the board at the top of the list.
Mike Samples
#3 Posted : Friday, December 24, 2010 7:48:28 PM(UTC)
Mike Samples
Thanks, you've answered my question perfectly. I appreciate it!
Washer - Slow Cold Water Fill Rate (Washer Repair)
by dewaldg 4/2/2014 6:15:10 AM(UTC)
GE Front Load Washer No Cold Water Fill (Washer Repair)
by RaB1 2/11/2013 1:02:10 PM(UTC)
Cold water fills slowly (Washer Repair)
by gcfuller1979 7/29/2012 7:23:22 AM(UTC)
cold water fills even when machine is off (Washer Repair)
by nybob 9/24/2011 4:50:07 AM(UTC)
Whirlpool combo washer cold water fills slow (Washer Repair)
by TammyJJ 4/23/2011 11:13:13 AM(UTC)
cold water fill (Washer Repair)
by coriann 2/4/2011 6:30:19 PM(UTC)
Problem with cold water fill hose on washing machine. (Washer Repair)
by Need2WashMyClothesplzthx 12/9/2010 12:07:16 AM(UTC)
Cold water fill. (Washer Repair)
by gpers 11/18/2010 7:56:25 AM(UTC)
Maytag washer will not agitate/cold water fill won't shut off (Washer Repair)
by denise2855 8/3/2010 2:14:09 PM(UTC)
cold water fill without machine on. (Washer Repair)
by ron baker 9/16/2009 3:35:52 PM(UTC)
Cold water fills very slow (Washer Repair)
by dreyn 7/13/2009 11:18:54 AM(UTC)
Slow cold water fill (Washer Repair)
by skirven2 4/25/2008 7:59:40 AM(UTC)
