Discuss
My Agitator on my Maytag Washer Seems to turn kind of hard!
 in
Washer Repair
I own a Maytag Washer and the agitaor seems to go a bit hard. I was using it and there
Appliance Repair Forum > Appliance Repair Help > Washer Repair » My Agitator on my Maytag Washer Seems to turn kind of hard!
  #1 (permalink)
Old 12-22-2010, 10:15 AM
Junior Member
videoproco is on a distinguished road
Default My Agitator on my Maytag Washer Seems to turn kind of hard!
Model Number: A612   Brand: Maytag   Age: More than 10 years
I own a Maytag Washer and the agitaor seems to go a bit hard. I was using it and there was a odor of something smelling hot. Like Rubber smell.
I looked at the belts and them seem to be a bit lose and I do believe that the smell is coming from the belt. It must be slipping. So would a new belt solve the problem or is it in the transmission or agitator end of it?? Please let me know.
Jim at Videoproco
Ads By Google
Related Models
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A612ST Washer - Top Loading
Maytag A612T Washer - Top Loading
Maytag A613 WASHER-TOP LOADING
Maytag A613T Washer - Top Loading
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626 Misc / Accessory
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A626W Misc / Accessory
Jenn-Air A627B Misc / Accessory
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A712T Washer - Top Loading
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
Maytag A8420 WASHER-TOP LOADING
Maytag A8440 WASHER-TOP LOADING
Maytag A8500 WASHER-TOP LOADING
Maytag A8520 WASHER-TOP LOADING
Maytag A8600 WASHER-TOP LOADING
Admiral A8610PA SURFACE UNIT- ELE
Admiral A8610PS SURFACE UNIT- ELE
Admiral A8610PV SURFACE UNIT- ELE
Maytag A8640 WASHER-TOP LOADING
Maytag A8650 WASHER-TOP LOADING
Admiral A8670PB SURFACE UNIT- ELE
Admiral A8670PV SURFACE UNIT- ELE
Admiral A86LW-1-R SURFACE UNIT- ELE
Maytag A8700 WASHER-TOP LOADING
Admiral A8720PA SURFACE UNIT- ELE
Admiral A8720PW SURFACE UNIT- ELE
Maytag A8740 WASHER-TOP LOADING
Maytag A8800 WASHER-TOP LOADING
Maytag A882 WASHER-TOP LOADING
Maytag A8820 WASHER-TOP LOADING
Maytag A882T Washer - Top Loading
Maytag A883 WASHER-TOP LOADING
Maytag A883T Washer - Top Loading
Maytag A884 WASHER-TOP LOADING
Maytag A8840 WASHER-TOP LOADING
Maytag A884T Washer - Top Loading
Admiral A88FK-1 SURFACE UNIT- ELE
Admiral A88FK-2-R SURFACE UNIT- ELE
Admiral A88FK-6-R SURFACE UNIT- ELE
Admiral A88FN-2-R SURFACE UNIT- ELE
Admiral A88FN-2R SURFACE UNIT- ELE
Admiral A88LK-6-R SURFACE UNIT- ELE
Admiral A88LN-6-R SURFACE UNIT- ELE
Admiral A89L-4-R SURFACE UNIT- ELE
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
Frigidaire A8MECC2 Frg(v15) / Room Air Conditioner
Frigidaire A8MECD2 Frg(v21) / Room Air Conditioner
Frigidaire A8MECUC2 Frg(v16) / Room Air Conditioner
  #2 (permalink)
Old 12-24-2010, 07:02 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This is a difficult diagnosis to make on a Forum, because there can be a number of potential causes of your problem.
I doubt if it is the belt, more likely the transmission given the age of your machine. I suggest you consider replacement, since new basic top loaders are being heavily discounted, and putting more money and time into your current washer may not be the best use of those resources.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer agitator belt hard to turn handyman Glenn Washer Repair 1 09-21-2010 05:21 PM
Maytag Washer - Agitator Problem Baby Doll 007 Washer Repair 1 09-12-2009 04:34 PM
Kind Of oil for Agitator drive - Amana DAVIDC19755 Washer Repair 0 09-08-2009 02:34 PM
Whirlpool washer agitator won't turn during wash cycle. Bill Armstrong Washer Repair 2 07-29-2009 02:29 PM
Washer Agitator won't turn nflordeliza Washer Repair 2 10-17-2007 05:04 PM
