Discuss
Basket Seems Stuck
 in
Washer Repair
Hi! I have a Whirlpool direct-drive, SAWS800HQ (costco). The Age field says 1 year...my mistake...it's actually
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Basket Seems Stuck
  #1 (permalink)
Old 07-25-2007, 06:17 PM
Nick Nick is offline
Junior Member
Nick is on a distinguished road
Default Basket Seems Stuck
Model Number: SAWS800HQ   Brand: Whirlpool   Age: Less than 1 year
Hi! I have a Whirlpool direct-drive, SAWS800HQ (costco). The Age field says 1 year...my mistake...it's actually about 7 or 8 years old.
I replaced the brake+drive tube assembly (bought part here...great site!)
The drive tube spins fine during testing while assembling.
But when I set the tub on it and tighten the spanner nut, the tub no longer spins. It looks like what's happening is that as I tighten the spanner, the drive block gets pressed down against the top of the support tube, causing the basket to bind up.
Question: when I press the drive block down on the drive tube, is it supposed to wind up flush with the top of the Drive Tube...so that only those two little square ears protrude above the drive block? OR, is the drive block supposed to be pressed all the way down the tube till it rests on the top of the Support tube? (note: If I press it all the way down, I wind up with about 1/2 " or so of drive tube sticking up above the top of the drive block.)
If I keep the drive block flush with the top of the drive tube, then things work fine...but I'm not able to tighten the spanner nut tight enough to keep the drive block from slowly sliding down the tube until it hits the top of the support tube, and binds things up again (I don't have a spanner wrench, I'm using a pipe wrench and cinching it up with a hammer and punch)
Am I missing a part, some kind of bearing or something that sits between the top of the Support tube and the bottom of the Drive block? (So that the block doesn't bind up against the top of the support tube.)
Should I be able to tighten that drive block enough to prevent it from working its way down the drive tube till it rubs against the top of the support tube? (I have a feeling this is the case...and that I may need to get a spanner wrench. I'm also wondering if I need a new drive block.)
ANY help would be greatly appreciated...I've been fighting this for a week...the clothes are piling up! ;-)
Thanks folks.
--Nick
Related Models
Whirlpool SAWS800HQ0
Whirlpool SAWS800JQ0
Whirlpool SAWS800JQ1
Whirlpool SAWS800JQ2
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
Amana SBD20Q2E Ref - SXS/I&W
Amana SBD20Q2W Ref - SXS/I&W
Amana SBD20S4E Ref - SXS/I&W
Amana SBD20S4L Ref - SXS/I&W
Amana SBD20S4W Ref - SXS/I&W
Amana SBD20TPE Ref - SXS/I&W
Amana SBD20TPL Ref - SXS/I&W
Amana SBD20TPSW Ref - SXS/I&W
Amana SBD20TPW Ref - SXS/I&W
Amana SBD21VE Ref - SXS/I&W
Amana SBD21VL Ref - SXS/I&W
Amana SBD21VPE Ref - SXS/I&W
Amana SBD21VPSE Ref - SXS/I&W
Amana SBD21VW Ref - SXS/I&W
Amana SBD522VE Ref - SXS/I&W
Amana SBDE20S4SW Ref - SXS/I&W
Amana SBDE20TPE Ref - SXS/I&W
Amana SBDE20TPW Ref - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
