My Maytag Neptune mah5500b will fill with water but then will do nothing. Any suggestions on the replacement part I would need?
Maytag is now limiting access to their tech data, but you should have a tech sheet inside the console. If so, use it to put the machine into a diagnostic mode and see if it will specify the problem.
The Motor Control Unit is a likely suspect, but so is the door lock mechanism, the Control Unit and the wiring.
