Discuss
Kenmore 80 Series drops "lock" from drain to spin; spins while draining
 in
Washer Repair
I don't believe it... I've seen a few washers with this problem, and I searched around but found nothing at
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 80 Series drops "lock" from drain to spin; spins while draining
  #1 (permalink)
Old 12-16-2010, 08:37 PM
Junior Member
FalconFour is on a distinguished road
Question Kenmore 80 Series drops "lock" from drain to spin; spins while draining
Model Number: 110.25842400   Brand: Kenmore   Age: 5 - 10 years
I don't believe it... I've seen a few washers with this problem, and I searched around but found nothing at all.
A friend of mine just got a Kenmore 80 Series washer. Looks pretty new, still has the blue plastic on the front panel, though it's kinda... melded with the panel now. I know it's over 5 years old just looking at the internals. Today we replaced the clutch and agitator dogs. That was fun.
But it still has the problem that caused the clutch to burn out to begin with: it spins while draining. As I know about these Kenmore washers, they use 1 motor to agitate, drain, and spin. The motor goes one direction to agitate, the other direction to drain and spin. When it changes direction, the transmission locks out the spin for the first "reversal", until the motor lowers speed (stops) and it disengages this "neutral lock" and engages the spin upon the next activation of the motor in the same direction. So the timer box is supposed to go agitate (forward) -> pause -> drain (reverse) -> pause -> spin (reverse).
Problem is, it "drains" for about 1 second before the transmission loses that "lock" and starts spinning while the basket is full of water, instead of waiting for the timer to stop the motor so it can disengage. That burns through the clutch big time as it spins slowly for about 30 seconds-1 minute while still full of water.
I had the transmission case opened up earlier today to see what could possibly be causing that, but I didn't have the proper tools or guidance to confidently go into it. I ended up reassembling it and hoping the new clutch would fix it. It certainly spins faster and gets up to speed quicker now, but like clockwork, it always misses the "neutral-lockout" and starts spinning right after an agitate. This can't keep going on like this, I told my friend he'll probably have another month before he burns out this clutch as well (and he was NOT happy with paying $50 for the clutch either).
What can be done to fix this, in the transmission or otherwise?
edit: Oohh, using the "model" link above, I learned the phrase I was looking to search for: "neutral drain". I was searching for "drain before spin" or "spinning while draining". Using the phrase "neutral drain" I found a bunch of new info. But I could still use a pointer if anyone has any advice
Ads By Google
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 12-18-2010, 05:00 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Your problem likely is in the transmission. To pump out the water the motor reverses itself and the transmission goes into neutral. Your transmission will not stay in neutral. You can try rebuilding the transmission or you can replace it.
Here is a service manual that may hellp.
https://secured.whirlpool.com/Servic...$FILE/L-55.pdf
__________________
  #3 (permalink)
Old 12-19-2010, 10:39 PM
Junior Member
Default
Well, cheapskate friend decided it works well enough as it is (I beg to differ), and that he ran a load and watched it, and that it was actually working fine. Weird. Maybe I wasn't giving it enough agitating time to reset the neutral-drain mechanism (I was originally under the impression that it "sets" itself as soon as it goes into agitate, I was testing it with just 1-2 seconds of agitating). Or maybe it still is messed up...
I found this kit to repair the neutral-drain:
Part Details - WHIRLPOOL Neutral drain kit, part number: AP3018165
Maybe if it's still having problems, I'll replace that (and yeah, I know it involves tearing apart the transmission, but that's the fun part!). Also helps to know I should take the motor off the transmission before removing it next time... had a pain-in-the-arse of a time getting it out last time
  #4 (permalink)
Old 12-20-2010, 06:14 AM
Senior Expert
APP Volunteer
Default
Sounds like you are on top of it.
Good luck!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore oven defaults from "bake" to "broil" big blue Oven Repair (including Ranges and Cooktops) 0 11-06-2010 03:26 PM
Oven "Lock" light flass, door unlocked jb3000jb Oven Repair (including Ranges and Cooktops) 0 11-22-2009 12:10 PM
Kenmore HE3T Loud "Clacking" during high speed spin nowhere Washer Repair 1 06-29-2009 07:24 AM
Gallery Series ""Water Wont Go In"" juancruz Washer Repair 1 04-28-2009 06:06 PM
Freezer: after defrost, water drips, then leaves frozen "ice drops" Troubleshooter Refrigerator & Freezer Repair 3 04-03-2009 12:23 PM
