Discuss
Two drain lines?
 in
Washer Repair
I have just aquired this washing machine, after a long struggle with my front loading Maytag (which worked flawlessly both
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Two drain lines?
  #1 (permalink)
Old 12-16-2010, 02:44 PM
Junior Member
jjnemoiii is on a distinguished road
Default Two drain lines?
Model Number: 11082979100   Brand: Kenmore   Age: More than 10 years
I have just aquired this washing machine, after a long struggle with my front loading Maytag (which worked flawlessly both times I took it in). This washer has two drain lines, which I have never seen before. To use it, I have run a 2ft length of Washer drain hose to a 1" Tee, where I tied in both drain hoses. Did I do this correctly? Why do I have two drains? I read something about "suds recovery" on this machine, is this why I have two drains, and can you tell me what suds recovery is all about?
Merry Christmas!
Thank You!
Joe
Ads By Google
Related Models
Kenmore 11083074130 WASHER
Kenmore 11083074230 WASHER
Kenmore 11083074430 WASHER
Kenmore 11083074630 WASHER
Kenmore 11083074830 WASHER
Kenmore 11083075120 SEARS ELECTRIC WASHER
Kenmore 11083075220 SEARS ELECTRIC WASHER
Kenmore 11083075420 SEARS ELECTRIC WASHER
Kenmore 11083075620 SEARS ELECTRIC WASHER
Kenmore 11083075820 SEARS ELECTRIC WASHER
Kenmore 11083150100 SEARS ELECTRIC WASHER
Kenmore 11083150110 SEARS ELECTRIC WASHER
Kenmore 11083151110 SEARS ELECTRIC WASHER
Kenmore 11083170100 SEARS ELECTRIC WASHER
Kenmore 11083170400 SEARS ELECTRIC WASHER
Kenmore 11083170600 SEARS ELECTRIC WASHER
Kenmore 11083170800 SEARS ELECTRIC WASHER
Kenmore 11083171110 SEARS ELECTRIC WASHER
Kenmore 11083171410 SEARS ELECTRIC WASHER
Kenmore 11083171610 SEARS ELECTRIC WASHER
Kenmore 11083171810 SEARS ELECTRIC WASHER
Kenmore 11083172100 SEARS ELECTRIC WASHER
Kenmore 11083172110 SEARS ELECTRIC WASHER
Kenmore 11083172130 WASHER
Kenmore 11083172200 SEARS ELECTRIC WASHER
Kenmore 11083172210 SEARS ELECTRIC WASHER
Kenmore 11083172230 WASHER
Kenmore 11083172400 SEARS ELECTRIC WASHER
Kenmore 11083172410 SEARS ELECTRIC WASHER
Kenmore 11083172430 WASHER
Kenmore 11083172600 SEARS ELECTRIC WASHER
Kenmore 11083172610 SEARS ELECTRIC WASHER
Kenmore 11083172630 WASHER
Kenmore 11083172800 SEARS ELECTRIC WASHER
Kenmore 11083172810 SEARS ELECTRIC WASHER
Kenmore 11083172830 WASHER
Kenmore 1108318272 GAS BURNER
Kenmore 1108318276 GAS BURNER
Kenmore 11083194100 SEARS ELECTRIC WASHER
Kenmore 11083194110 SEARS ELECTRIC WASHER
Kenmore 11083194120 SEARS ELECTRIC WASHER
Kenmore 11083194140 SEARS ELECTRIC WASHER
Kenmore 11083194200 SEARS ELECTRIC WASHER
Kenmore 11083194210 SEARS ELECTRIC WASHER
Kenmore 11083194220 SEARS ELECTRIC WASHER
Kenmore 11083194240 SEARS ELECTRIC WASHER
Kenmore 11083194400 SEARS ELECTRIC WASHER
Kenmore 11083194410 SEARS ELECTRIC WASHER
Kenmore 11083194420 SEARS ELECTRIC WASHER
Kenmore 11084050100 AUTOMATIC WASHER
Kenmore 11084050110 AUTOMATIC WASHER
Kenmore 11084050120 AUTOMATIC WASHER
Kenmore 11084070100 AUTOMATIC WASHER
Kenmore 11084070110 AUTOMATIC WASHER
Kenmore 11084070120 AUTOMATIC WASHER
Kenmore 11084070800 AUTOMATIC WASHER
Kenmore 11084070810 AUTOMATIC WASHER
Kenmore 11084070820 AUTOMATIC WASHER
Kenmore 11084090100 AUTOMATIC WASHER
Kenmore 11084090110 AUTOMATIC WASHER
Kenmore 11084090120 AUTOMATIC WASHER
Kenmore 11084090130 AUTOMATIC WASHER
Kenmore 11084090200 AUTOMATIC WASHER
Kenmore 11084090210 AUTOMATIC WASHER
Kenmore 11084090220 AUTOMATIC WASHER
Kenmore 11084090230 AUTOMATIC WASHER
Kenmore 11084090400 AUTOMATIC WASHER
Kenmore 11084090410 AUTOMATIC WASHER
Kenmore 11084090420 AUTOMATIC WASHER
Kenmore 11084090430 AUTOMATIC WASHER
Kenmore 11084090600 AUTOMATIC WASHER
Kenmore 11084090610 AUTOMATIC WASHER
Kenmore 11084090620 AUTOMATIC WASHER
Kenmore 11084090630 AUTOMATIC WASHER
Kenmore 11084090800 AUTOMATIC WASHER
Kenmore 11084090810 AUTOMATIC WASHER
Kenmore 11084090820 AUTOMATIC WASHER
Kenmore 11084090830 AUTOMATIC WASHER
Kenmore 11084350100 ELECTRIC WASHER
Kenmore 11084370100 ELECTRIC WASHER
Kenmore 11084370110 ELECTRIC WASHER
Kenmore 11084370800 ELECTRIC WASHER
Kenmore 11084370810 ELECTRIC WASHER
Kenmore 11084390100 ELECTRIC WASHER
Kenmore 11084390110 ELECTRIC WASHER
Kenmore 11084390200 ELECTRIC WASHER
Kenmore 11084390210 ELECTRIC WASHER
Kenmore 11084390300 ELECTRIC WASHER
Kenmore 11084390310 ELECTRIC WASHER
Kenmore 11084390400 ELECTRIC WASHER
Kenmore 11084390410 ELECTRIC WASHER
Kenmore 11084390600 ELECTRIC WASHER
Kenmore 11084390610 ELECTRIC WASHER
Kenmore 11085155100 SEARS ELECTRIC WASHER
Kenmore 11085156100 SEARS ELECTRIC WASHER
Kenmore 11085165100 SEARS ELECTRIC WASHER
Kenmore 11085165400 SEARS ELECTRIC WASHER
Kenmore 11085165600 SEARS ELECTRIC WASHER
Kenmore 11085165800 SEARS ELECTRIC WASHER
Kenmore 11085166100 ELECTRIC WASHER
Kenmore 11085175100 SEARS ELECTRIC WASHER
Kenmore 11085175200 SEARS ELECTRIC WASHER
Kenmore 11085175400 SEARS ELECTRIC WASHER
Kenmore 11085175600 SEARS ELECTRIC WASHER
Kenmore 11085175800 SEARS ELECTRIC WASHER
Kenmore 11085185100 SEARS ELECTRIC WASHER
Kenmore 11085185400 SEARS ELECTRIC WASHER
Kenmore 11085185600 SEARS ELECTRIC WASHER
Kenmore 11085185800 SEARS ELECTRIC WASHER
Kenmore 11085257100 ELECTRIC WASHER
Kenmore 11085365100 WASHER
Kenmore 11085365200 WASHER
Kenmore 11085365400 WASHER
Kenmore 11085365600 WASHER
Kenmore 11085365800 WASHER
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
Kenmore 11086070600 ELECTRIC DRYER
  #2 (permalink)
Old 12-16-2010, 04:03 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Sounds like you got a sud save washer.
The reason for the two drain hoses is because the washer can save half the drain water and reuse it.
To save the water the one drain hose would go into a sud saver tub and the other drain hose down the drain.
Durring the drain cycle half the water gets save and pumped back into the tub with some regular fill water.
Suds save washers have not been made for years now and I have not worked on one for a good 5 years or so.
Most of the time the sud save valves would fail and I would just end up bypassing them, more or less turning them in to a standard top load washer.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-16-2010, 04:04 PM
Senior Expert
APP Volunteer
Default
It maybe stamped on the back of the washer were the drain hoses connect as to what hose is the main drain hose and what hose is the suds saver hose.
__________________
  #4 (permalink)
Old 12-17-2010, 03:12 AM
Junior Member
Default
Thanks ApplianceJunk, I do basically already have it in use like a standard top load, works good so far that way, drain line is clearly marked, maybe I'll grab a bucket and try out the suds saver sometime.
Thanks for all the help,
Merry Christmas to all!
Joe
  #5 (permalink)
Old 12-18-2010, 06:33 AM
Junior Member
Default
In my searching on the internet, I was unable to locate an owners manual PDF. Does anyone know where I can either view or purchase one?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
4 lines in my compressor gottuhaveit Refrigerator & Freezer Repair 2 08-28-2010 02:11 AM
water lines Dan Dietrich Refrigerator & Freezer Repair 12 05-24-2010 10:34 PM
ice forming in compressor lines bebra Refrigerator & Freezer Repair 1 01-05-2009 07:11 PM
