| » Washer Issues |
Model Number: WTW5821SW0 Brand: Whirlpool Age: 1 - 5 years
I replaced the timer and the regular wash cycle worked until the end. In the end, a small amount of water was added, but it was not released.
I tried to run the same regular was cycle again and now it fills with water, skips the agitation cycle and then releases the water. Should I try replacing the circuit board? Or something else? Thank you for your time. I appreciate ANY guidance you might have. Ads By Google Related Models |
Quote:
If I ran the regular wash cycle, the washer fills with water to the appropriate level, but did not engage the agitation cycle. However, I was able to advance the cycle and let the water drain from the washer properly. If I ran the rinse portion of the quick wash cycle, the washer fills with water to the appropriate level, agitates, and engages the drain cycle. I think all of the functions work on the washer based on my responses above, but there is obviously some communication issues since the agitation appears to work in some cycles but not others. I REALLY APPRECIATE YOUR HELP!!!! |
It isn't common, BUT it is possible to get a bad timer, right out of the box. The first thing I would check is the connector(s) on the timer. Make sure there are no burnt terminals. also make sure everything in the connector lines up correctly, and the connections are secure.
Quote:
Just so I have an idea, what are potential symptoms of a bad circuit board? Just curious if it is worth trying to replace that part as well? |
| Display Modes | |
| washer issues on ge brand | Kelli Leahey | Washer Repair | 0 | 08-25-2010 11:44 AM |
| Washer Motor issues | brooks nelson | Washer Repair | 1 | 04-11-2010 08:03 AM |
| New Whirlpool Washer Issues | lisarvot@comcast.net | Washer Repair | 1 | 03-02-2009 02:30 AM |
| HELP !?#*& Washer Issues! | skidoohead | General Talk | 3 | 12-22-2008 02:03 AM |
| Frigidare Washer issues | Torwadeo | Washer Repair | 9 | 10-12-2008 11:28 AM |
