Discuss
Washer will not agitate
 in
Washer Repair
When I try to wash a load of clothes, the tub will fill. It will attempt to agitate, but no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not agitate
  #1 (permalink)
Old 12-16-2010, 07:06 AM
Junior Member
cb760 is on a distinguished road
Default Washer will not agitate
Model Number: FWX433RBS5   Brand: Frigidaire   Age: More than 10 years
When I try to wash a load of clothes, the tub will fill. It will attempt to agitate, but no success. It makes a humming noise & then clicks off. It will wait about 30 seconds, hum again & click off. I tried to move the timer to a different location & had the same results. Was able to move the cycle to 'final spin' & the pump did drain the tub & I believe it will spin then.
Any ideas?
Thanks,
Chan
Ads By Google
Related Models
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Maytag G Range - S/c F/s Gas
Hardwick G-433 Surface Unit - Ele
Hardwick G-436 Surface Unit - Ele
Hardwick G-445 Surface Unit - Ele
Jenn-Air G0206B-8 Electric Grill Outdoor
Jenn-Air G100 Surface Unit - Ddraft Ele
Jenn-Air G101 Surface Unit - Ddraft Ele
Jenn-Air G102 Surface Unit - Ddraft Ele
Jenn-Air G103 Surface Unit - Ddraft Ele
International G1110PRA Range - F/s Std Gas
International G1110PRW Range - F/s Std Gas
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
  #2 (permalink)
Old 12-16-2010, 07:42 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
I would first look under the agitator, to see if there is an article of clothing tangled around the shaft. It sounds like you have something jamming the agitation. If it isn't the agitator, it may be a transmission problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does everything except agitate beccado12774 Washer Repair 1 08-30-2010 05:47 PM
Washer does not agitate acekun Washer Repair 3 08-09-2010 01:16 AM
stackable washer dryer: washer will not agitate jennypatterson Dryer Repair 0 03-04-2009 11:08 AM
Washer won't agitate b_radnc Washer Repair 1 02-20-2009 04:39 PM
Washer will not agitate dveljko Washer Repair 13 11-20-2008 11:11 AM
