Washer will not agitate
When I try to wash a load of clothes, the tub will fill. It will attempt to agitate, but no success. It makes a humming noise & then clicks off. It will wait about 30 seconds, hum again & click off. I tried to move the timer to a different location & had the same results. Was able to move the cycle to 'final spin' & the pump did drain the tub & I believe it will spin then.
Any ideas? Thanks, Chan |
I would first look under the agitator, to see if there is an article of clothing tangled around the shaft. It sounds like you have something jamming the agitation. If it isn't the agitator, it may be a transmission problem.
| All times are GMT -7. The time now is 07:20 AM. |
