| » Neptune support repair |
Model Number: mah4000aww Brand: Maytag Age: 5 - 10 years
Purchaced the support part(W10181639) from you but I cannot get it to seat into the outer drum assy far enough for the pulley bolt to engage the threads in the support assy. The seal kit does not touch the O ring at the base of the support part. Is it possible for the seal kit to be in backwards or wrong part?
Quote:
Did you recieve the parts installation instruction sheet Part No. 16021976 ? Are you sure the shaft "O" ring is all the way down and against the smooth surface at the bottom of the support shaft, against the support arm assembly(page 6 or the instruction sheet) ? Yes, it is possible to install the seal backwards, Several ways to check , A) The seal has 3 ribs molded into the outer edge, the end with the ribs should be seated into the outer tub assembly, in front of the tub bearing,and seated against the bearing face. B) The front of the seal, will have a 1/4 inch "lip" molded into it, the lip should be facing out(towards you, or the back side of the spin tub, support assembly. Installing the "new" shaft washer and nut, may,be difficult, but not like what you're describing. Unless something is not seated correctly.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Quote:
No, the small 90 degree angled part of the seal assembly (the large metal interior plate of the seal) should, both face in towards the bearing, back of the machine. As for a replacement part, I believe APP will replace the part, but you'd need to contact the Parts Pro Team at 1-877-477-7278 for any assistance as for parts information.
__________________
| Display Modes | |
| Crisper support pins repair | ktm3060 | Refrigerator & Freezer Repair | 3 | 04-22-2010 12:50 PM |
| Buying a New Dishwasher - What Brands Have Best DIY Repair Support and Reliability??? | user667 | Dishwasher Repair | 0 | 03-07-2010 05:06 PM |
| Maytag Neptune broken spinner support bolts | Barnaby | Washer Repair | 2 | 12-06-2009 09:44 AM |
| Neptune repair | Terri Meester | Washer Repair | 1 | 10-08-2008 03:01 PM |
| Maytag Neptune Q6/ R11 repair alternate | richappy | General Talk | 0 | 03-06-2008 04:04 AM |
