Discuss
Kenmore washer not spinning, makes grinding noise
 in
Washer Repair
I just bought this washer used and it makes a grinding noise during the spin cycle and the agitator does
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer not spinning, makes grinding noise
  #1 (permalink)
Old 12-15-2010, 07:16 PM
Junior Member
mortica101 is on a distinguished road
Default Kenmore washer not spinning, makes grinding noise
Model Number: 110.28803890   Brand: Kenmore   Age: 5 - 10 years
I just bought this washer used and it makes a grinding noise during the spin cycle and the agitator does not agitate at all. Could this be a simple problem as the coupler needing to be replaced on this particular model? Any suggestions?
Ads By Google
Related Models
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
Kenmore 110.5808850  KENMORE ELECTRIC DRYER
Kenmore 110.5808860  KENMORE ELECTRIC DRYER
Kenmore 110.5808950  KENMORE ELECTRIC DRYER
Kenmore 110.5808960  KENMORE ELECTRIC DRYER
Kenmore 110.5817500  KENMORE GAS DRYER
Kenmore 110.5817501  KENMORE GAS DRYER
Kenmore 110.5817800  KENMORE GAS DRYER
  #2 (permalink)
Old 12-16-2010, 04:55 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
BINGO!!!! Here is a website that will give you step by step instruction. How to Replace Whirlpool Washer Couplers Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore makes grinding noise ACSPLACE Washer Repair 3 11-14-2010 02:37 PM
Washer makes grinding noise during spin vmart Dishwasher Repair 0 10-21-2009 07:11 PM
Washer makes grinding noise. Joseph01 Washer Repair 1 09-02-2009 05:50 AM
makes grinding noise when spinning markcopelli Washer Repair 0 06-09-2008 11:18 AM
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 07:24 AM
