Discuss
front loader drum jams
 in
Washer Repair
My front loader washer drum hangs up now and then. I can force it to turn and feel something move
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front loader drum jams
  #1 (permalink)
Old 12-15-2010, 04:28 PM
Junior Member
kenbary is on a distinguished road
Unhappy front loader drum jams
Model Number: LTF2140ES0   Brand: Frigidaire   Age: 1 - 5 years
My front loader washer drum hangs up now and then. I can force it to turn and feel something move free maybe a sock or something got through the seal and is on the outer side of the drum getting caught. It will happen again and again after I turn it mannualy and then run it. Where do I begin to open the unit. Front Back Top etc.
Any help would be appreaciated
kenbary@comcast.net
Ads By Google
Related Models
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Whirlpool LTG5243BN0
Whirlpool LTG5243BN1
Whirlpool LTG5243BN2
Whirlpool LTG5243BW0
Whirlpool LTG5243BW1
Whirlpool LTG5243BW2
Whirlpool LTG5243DQ0
Whirlpool LTG5243DQ1
Whirlpool LTG5243DQ2
Whirlpool LTG5243DQ3
Whirlpool LTG5243DQ4 Washer/dryer Laundry System
Whirlpool LTG5243DQ5 Washer/dryer Laundry System
Whirlpool LTG5243DQ6 Washer/dryer Laundry System
Whirlpool LTG5243DQ7 Washer/dryer Laundry System
Whirlpool LTG5243DT2
Whirlpool LTG5243DT3
Whirlpool LTG5243DT4 Washer/dryer Laundry System
Whirlpool LTG5243DT5 Washer/dryer Laundry System
Whirlpool LTG5243DT6 Washer/dryer Laundry System
Whirlpool LTG5243DT7 Washer/dryer Laundry System
Whirlpool LTG5243DZ0
Whirlpool LTG5243DZ1
Whirlpool LTG5243DZ2
Whirlpool LTG6234AN0
Whirlpool LTG6234AN1
Whirlpool LTG6234AN2
Whirlpool LTG6234AN3
Whirlpool LTG6234AW0
Whirlpool LTG6234AW1
Whirlpool LTG6234AW2
Whirlpool LTG6234AW3
Whirlpool LTG6234DQ0
Whirlpool LTG6234DQ1
Whirlpool LTG6234DQ2 Washer/dryer Laundry System
Whirlpool LTG6234DQ3 Washer/dryer Laundry System
Whirlpool LTG6234DQ4 Washer/dryer Laundry System
Whirlpool LTG6234DQ5 Washer/dryer Laundry System
Whirlpool LTG6234DT1
Whirlpool LTG6234DT2 Washer/dryer Laundry System
Whirlpool LTG6234DT3 Washer/dryer Laundry System
Whirlpool LTG6234DT4 Washer/dryer Laundry System
Whirlpool LTG6234DT5 Washer/dryer Laundry System
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1
Whirlpool LTG7245AN0
Whirlpool LTG7245AW0
Whirlpool LUD2100X0
Whirlpool LUD2100X1
Whirlpool LUD2100X3
Whirlpool LUD2100X4
Whirlpool LUD2100X5
Whirlpool LUD2100X6
Whirlpool LUD2100X7
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
Whirlpool LV55
Whirlpool LV551
Whirlpool LV5511
Whirlpool LV651
Whirlpool LVA4000W0
Whirlpool LVA4000W1
Whirlpool LVA4000W2
Whirlpool LVA4000W3
Whirlpool LVA4000W4
Whirlpool LVA4000W5
Whirlpool LVA4000W6
Whirlpool LVA4000W7
Whirlpool LVA4005W0
Whirlpool LVA4005W1
Whirlpool LVA4005W2
Whirlpool LVA4005W3
Whirlpool LVA4005W4
Whirlpool LVA4005W5
Whirlpool LVA4005W6
Whirlpool LVA4005W7
Whirlpool LVA4800W0
Whirlpool LVA4805W0
Whirlpool LVA4805W1
Whirlpool LVA5300W0
Whirlpool LVA5300W1
Whirlpool LVA5304W0
Whirlpool LVA5304W1
Whirlpool LVA5305W0
Whirlpool LVA5305W1
Whirlpool LVA5309W0
Whirlpool LVA5309W1
Whirlpool LVA5400W0
Whirlpool LVA5405W0
Whirlpool LVA5500W0
Whirlpool LVA5505W0
Whirlpool LVA5540W0
Whirlpool LVA5540W1
Whirlpool LVA5545W0
Whirlpool LVA5545W1
Whirlpool LVA5560W0
Whirlpool LVA5560W1
  #2 (permalink)
Old 12-16-2010, 02:38 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You will need to remove the tub to pump drain hose to fish out any stuck item. You might find the wire clamp imposable to get back on, so you will need to buy a adjustable clamp to replace it.
__________________
  #3 (permalink)
Old 12-16-2010, 04:59 AM
Junior Member
Default stuck 2
Do you know what section to remove first? Back or front or top???
I never openend this one before.
  #4 (permalink)
Old 12-17-2010, 01:20 AM
Senior Expert
APP Volunteer
Default
You remove the torque screws under the bottom front kick panel, then remove panel.
__________________
  #5 (permalink)
Old 12-17-2010, 04:56 AM
Junior Member
Default
Thanks, I will have to wait till Saturday to give it a try
I know these things take more time than you expect.
  #6 (permalink)
Old 12-17-2010, 06:01 AM
Senior Expert
APP Volunteer
Default
I forgot, all Frigidaire front loaders have a access panel in the back. Warning!!, Before reaching in, use duck tape on the very sharp edges back there, will save cuts and prevent foul language around Christmas!
__________________
  #7 (permalink)
Old 12-19-2010, 09:34 AM
Junior Member
Default
trying to open the frigidaire front loader to look for stuck item
The back pannel doesnt give me access to see between inner basket and drum.
Should I try front pannel?
  #8 (permalink)
Old 12-19-2010, 09:38 AM
Senior Expert
APP Volunteer
Default
You can't gain access to the inside of the tub, all you can do is remove the drain hose and fish out anything there
__________________
  #9 (permalink)
Old 12-19-2010, 10:30 AM
Junior Member
Default
I think I got it. Before I opened it I ran a dry spin and heard a good couple of thumps. Shut it down and opened it. Got the drain clamp off and drain hose. A sock made its way to the drain. I was right there, I just plucked it out and put drain hose clamp back on. doing a test wash right now.
Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Loader drum wont turn jtoddrn Washer Repair 3 04-13-2010 01:38 PM
Front Loader drum won't spin/agitate mfidds Washer Repair 1 07-25-2009 07:01 AM
leaking front loader door /drum seal bfd Washer Repair 0 12-22-2008 07:21 PM
Loose drum in Maytag front loader Lynton Washer Repair 1 02-10-2008 04:27 AM
problem with loose drum inside front loader Big G Washer Repair 1 12-18-2007 03:04 PM
