| » Washer does not spin. |
Model Number: LLR6144BNO Brand: Whirlpool Age: More than 10 years
Washer fills, agitates, drains OK. Basket does not spin with clothes in machine but makes a loud "clicking" noise. The agitator moves @ spin cycle when no clothes in machine but basket does not spin. Thoughts?
The lid switch seems to be OK...all operative cycles (fill, agitate, drain) work with lid open and switch depressed with a screwdriver, but basket does not move @ spin cycle. Ads By Google Related Models |
Quote:
Check and make sure there is nothing stuck between the tubs.(you can look through the perforations in the tub, or see if you can manually turn the tub without a drag on it. My first suspicion would be a bent/ broken drive coupling and or a slipping clutch Part number: AP3963893 Part number: AP3094537 There are other possibilities, but these are the most common repairs for your washer complaint. Here is a post from our repair forum, it'll have all the info you need, Replacing direct drive washer brake shoes
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Good deal, We'll keep an eye out for your update. Good Luck, Happy Holidays,
__________________
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| washer makes grinding noise and won't spin on spin cycle | marine1969 | Washer Repair | 1 | 08-30-2010 07:19 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
