| » intsatlling washer boot how to? |
Model Number: wfw9200sqa12 Brand: Whirlpool Age: 1 - 5 years
Can you tell me how to unlock clamp on current boot and install new washer boot?
Thank you, Caragh O'Brien Ads By Google Related Models |
Quote:
It's a pretty involved procedure, not very difficult, could be frustrating at times, but here are excerpts from the Service Manual, to help you through, Good Luck, REMOVING THE DOOR SWITCH ASSEMBLY AND THE BELLOWS1. Unplug washer or disconnect power. 2. Turn off the water supply to the washer. 3. Remove the top cover and the console 4. Remove the lower front access panel 5. Open the washer door 6. Using a small screwdriver or a pair of long-nosed pliers, pull the tension spring on the retaining wire out from around the front of the bellows, and remove the wire. 7. To remove the door switch assembly: a) Pull the bellows off the lip of the front from the door switch assemblypanel beside the door switch assembly just enough to access the switch assembly. b) Remove the two T-20 Torx screws c) Pull the door switch assembly out and turn it over so that you can access the connectors. d) Unlock the tabs and disconnect the three wire connectors from the door switch terminals, then remove the assembly. 8. To remove the bellows: a) Remove the two T-20 Torx screws from the door switch assembly . b) Remove the front panel from the washer c) Turn the bellows retaining clamp screw counterclockwise until the clamp is loose enough to remove it from around the bellows NOTE: It may be necessary to completely remove the screw from one end of the clamp. d) Remove the bellows retaining clamp from around the bellows. e) Pull the bellows off the front of the tub. Remove Bellows REASSEMBLY NOTE: When you reinstall the bellows, be sure to position the “weep holes” at the bottom, as shown below. REMOVING THE CONSOLE AND THE TOUCHPAD/LED ASSEMBLY1. Unplug washer or disconnect power. cover, then lift the cover off the unit.2. Turn off the water supply to the washer. 3. Remove the three T-20 hex-head Torx screws from the top cover of the washer. 4. Pull back on the cover and release the tabs in the console from the slots in the 5. To remove the console: a) Pull out and disconnect cable connector central control unit clips.UI8 from the central control unit. b) Remove the cable wires from the two c) Pull the detergent dispenser drawer drawer from the unit.out as far as it will go, then press down on the release tab, and remove the d) Remove the two screws at the recessed hole and bottom of the console.e) Lift the top edge of the console and unhook it from the holder clips. f) Press the locking tab on the right rear the consoleside of the console inward, and remove 10. Remove the three hex-head screws from the panel, and remove it.the lower front access panel, then lower 11. Open the washer door. 12. Using a small screwdriver or a pair of long-nosed pliers, pull the tension spring on the retaining wire out from around the front of the bellows, and remove the wire. 13. Pull the bellows off the lip of the front panel, and push the bellows inside the front panel. 14. Remove the two T-20 Torx screws from the door switch assembly 15. Close the washer door. 16. Remove the four hex-head screws from the top and bottom of the front panel and remove the panel from the unit. 17. Loosen the clamp from the main water feed tube and remove the tube from the detergent dispenser. 18. Pull back and unhook the tab on the left out of the washerside of the detergent dispenser from the cabinet side panel slot, then lift the dispenser REASSEMBLY NOTE: When you reconnect the water feed tube, align the arrow on the tube with the line on the detergent dispenser
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Replacing boot on Neptune Washer | nrn | Washer Repair | 1 | 04-01-2011 05:32 PM |
| washer boot install | jhassel70 | Washer Repair | 0 | 12-14-2010 03:11 PM |
| Replacing boot on Maytag washer | JLH99 | Washer Repair | 2 | 09-15-2010 02:31 PM |
| Top load washer tub boot seal installation | PJTEXAS | Washer Repair | 4 | 08-22-2010 09:35 PM |
| washer boot gasket | rmatthews | Washer Repair | 3 | 12-21-2009 05:23 PM |
