Discuss
Whirlpool washer how to install transmission
 in
Washer Repair
I had the motor coupler go out. When I was trying to find the problem I took out the bolts
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer how to install transmission
  #1 (permalink)
Old 12-14-2010, 06:23 PM
Junior Member
sewerrat is on a distinguished road
Exclamation Whirlpool washer how to install transmission
Brand: Whirlpool   Age: More than 10 years
I had the motor coupler go out. When I was trying to find the problem I took out the bolts that hold the transmission on. I plulled it down and it lower about 1/2 to 3/4 of a inche. I have tried to bolt it back into place but I can not get it to go all the way back into place. It is a model LA5558XTW2. I hope it is a easy fix as the original part that broke is cheap.
Sewerrat
Ads By Google
  #2 (permalink)
Old 12-15-2010, 01:33 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Pull the tranny out all the way and oil the spindle. Check the location of the clutch tab to ensure it will not hit the plastic brake release tab on the bottom of the spin tube and make sure the thrust washer on top of the clutch is seated all the way. It should now slide in easily.
__________________
  #3 (permalink)
Old 12-04-2011, 03:32 PM
Junior Member
brewer is on a distinguished road
Default brewer
I have the same problem and don't think oil is the answer as it strikes something solid about 1/2 " before the transmission is all the way in.I have also studied the position of the plastic brake leaver and that is not the problem. The washer looking ring is in place before i slide the shaft in place but is slides out of position each time I remove the transmission.Could it be the position of the inner tub with respect to the outer tub? Sewerrat, did you resolve the problem?
  #4 (permalink)
Old 12-04-2011, 03:54 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Here is a youtube video from the appliancepartspros channel that maybe helpful.
Washer Gearcase (part #3360629) - How To Replace - YouTube
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #5 (permalink)
Old 12-04-2011, 04:22 PM
Senior Expert
APP Volunteer
Default
If the brake shoes are below the brake housing, the spin tube has slipped down, just release the brake shoes by squeezing the plastic paw and push up in place.
__________________
  #6 (permalink)
Old 12-06-2011, 07:25 AM
Junior Member
Default brewer
to richappy, You were correct and my washer is fixed now. The problem was hard to find because the washer was on its side and outdoors. There was some water trapped in the tub and frozen so the brake assy. would not budge even when I released it with the plastic paw.
  #7 (permalink)
Old 12-06-2011, 11:41 AM
Senior Expert
APP Volunteer
Default
You are lucky the skate plate did not go out of position. I never lay one of these down, allways just lean it back a lot, prevents problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer transmission SherylLee Washer Repair 3 10-02-2010 06:04 AM
tapping after transmission install wulleebullee Washer Repair 5 07-24-2010 04:46 AM
GE Washing Machine Transmission Install wcaron Washer Repair 0 10-07-2008 08:26 AM
transmission oil for washer? jen58 Washer Repair 1 04-08-2008 03:57 AM
