Discuss
Replaced Dog-Ears on Agitator but Top Agitator seems loose
 in
Washer Repair
I replaced the Dog-Ears on my top Agitator and now it no longer slips but, I noticed that the top
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replaced Dog-Ears on Agitator but Top Agitator seems loose
  #1 (permalink)
Old 12-14-2010, 04:10 PM
Junior Member
TomAllThumbs is on a distinguished road
Default Replaced Dog-Ears on Agitator but Top Agitator seems loose
Model Number: LST7233DQ1   Brand: Whirlpool   Age: 1 - 5 years
I noticed that the top Agitator seems to be rather loose and that could have contributed to the damage to the Dog-Ears.
I checked to be sure the two (2) clips fit into the slots of the top Agitator (some say they can just be broken off). Even then the top Agitator can be moved around fairly easily by hand. I thought that it would be snug.
There are no other pieces to change. The Bottom Agitator is very solid, no worn teeth, etc. Just some soap scum near the top where it fits under the sleeve of the top Agitator.
Some brands say that the top Agitator should snap into place but this one doesn't.
The agitator is not slipping with the new dog-ears but I'd like to avoid early damage if this looseness is a potential problem.
Thanks,
TomAllThumbs
Ads By Google
Related Models
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
 LSU122CE Air Conditioner
 LSU122HE Air Conditioner
 LSU180HE Air Conditioner
 LSU182CE Air Conditioner
 LSU182HE Air Conditioner
 LSU240HE Air Conditioner
 LSU242CE Air Conditioner
 LSU242HE Air Conditioner
 LSUC121PMA Air Conditioner
 LSUJ0910CL Air Conditioner
 LSUK1830CL Air Conditioner
 LSUK1830HL Air Conditioner
 LSUK2430CL Air Conditioner
Whirlpool LSV5132AG0
Whirlpool LSV5132AN0
Whirlpool LSV5132AW0
Whirlpool LSV6233AG0
Whirlpool LSV6233AN0
Whirlpool LSV6233AW0
Whirlpool LSV6234AN0
Whirlpool LSV6234AW0
Whirlpool LSV7233BG0
Whirlpool LSV7233BN0
Whirlpool LSV7233BQ0
Whirlpool LSV7233BW0
Whirlpool LSV7233DQ0
Whirlpool LSV7233DZ0
Whirlpool LSV7244AN0
Whirlpool LSV7244AQ0
Whirlpool LSV7244AW0
Whirlpool LSV7245AN0
Whirlpool LSV7245AQ0
Whirlpool LSV7245AW0
Whirlpool LSV8244BN0 AUTOMATIC WASHER
Whirlpool LSV8244BQ0 AUTOMATIC WASHER
Whirlpool LSV8244BW0 AUTOMATIC WASHER
Whirlpool LSV8244DQ0
Whirlpool LSV8244DZ0
Whirlpool LSV8245AN0
Whirlpool LSV8245AW0
Whirlpool LSV9244DQ0
Whirlpool LSV9244DZ0
Whirlpool LSV9245BN0
Whirlpool LSV9245BW0
Whirlpool LSV9355AN0
Whirlpool LSV9355AW0
Whirlpool LSV9355BN0
Whirlpool LSV9355BW0
Whirlpool LSW9245EQ0 AUTOMATIC WASHER
Whirlpool LSW9245EQ1 AUTOMATIC WASHER
Whirlpool LSW9245EQ2 AUTOMATIC WASHER
Whirlpool LSW9700PQ0 AUTOMATIC WASHER
Whirlpool LSW9700PQ1 AUTOMATIC WASHER
Whirlpool LSW9700PQ2 AUTOMATIC WASHER
Whirlpool LSW9750PW0 AUTOMATIC WASHER
Whirlpool LSW9750PW1 AUTOMATIC WASHER
Whirlpool LSW9750PW2 AUTOMATIC WASHER
Whirlpool LSW9750PW3 AUTOMATIC WASHER
 LT0810C Air Conditioner
 LT0810CR Air Conditioner
 LT1010C Air Conditioner
 LT1010CR Air Conditioner
 LT1030CR Air Conditioner
 LT1030H Air Conditioner
 LT1030HR Air Conditioner
 LT1210C Air Conditioner
 LT1210CR Air Conditioner
 LT1230C Air Conditioner
 LT1230CR Air Conditioner
 LT1230H Air Conditioner
 LT1230HR Air Conditioner
 LT1430CR Air Conditioner
Frigidaire LT150EXD2 Wwh(v1) / Tumble Action Washer
Frigidaire LT150EXF2 Wwh(v2) / Tumble Action Washer
Frigidaire LT150EXH2 Wwh(v3) / Tumble Action Washer
Frigidaire LT150EXV2 Wwh(v4) / Tumble Action Washer
Frigidaire LT150EXW2 Wwh(v5) / Tumble Action Washer
Frigidaire LT150JXD1 Wwh(v1) / Tumble Action Washer
Frigidaire LT150JXF1 Wwh(v2) / Tumble Action Washer
  #2 (permalink)
Old 02-14-2011, 04:27 PM
Junior Member
Bjarki is on a distinguished road
Default Did you get to the bottom of this issue ?
I was wondering if you figured out whether or not your agitator is supposed to wobble like that ?
Sincerely,
David
Thanks,
TomAllThumbs
  #3 (permalink)
Old 02-14-2011, 04:57 PM
Junior Member
Default
Hi David,
I didn't get any answers from the forum but I have been using the machine regularly with some "almost too big" loads and it is performing OK.
When the machine is loaded the laundry inside seems to keep the agitator from wobbling. It's just that when it was empty it seemed loose when the machine was running.
So in operation it appears to work OK.
Hope that helps even though it's not a definitive answer you may have been looking for. No slipping going on.
  #4 (permalink)
Old 02-14-2011, 05:38 PM
Junior Member
Default I have a similar issue too
Our upper agitator wobbles too, when the washer is empty. I ordered the replacement agitator repair kit and am waiting for it to arrive. I hope to correct our problem by replacing the dogs. It sounds like the wobbly issue you are having isn't stopping your washer from working properly though. Thanks.
David
Hi David,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loose agitator - GE fixim Washer Repair 2 12-07-2010 04:58 PM
Agitator has come loose from base cdotson Washer Repair 0 08-25-2010 11:12 AM
Loose agitator Cherokee Cowboy Washer Repair 1 11-14-2009 04:08 PM
My Agitator spins freely...is it the dog ears? hawaiicity Washer Repair 2 01-22-2009 05:03 AM
Loose Agitator NelsonT Washer Repair 0 12-22-2008 02:08 PM
