| » Kenmore HE3 Washer F02 Error Code |
F2 means the machine didn't pump out in the 8 minutes it has over sudsing can cause this from not using "HE" detergent The pump may look good but replace it anyway.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed
__________________
Had this problem on our Kenmore machine.
This is what done. 1. Unplug the washer 2. Take of the toe panel in the front by removing the three screws. 3. Get a bunch of towels (I mean a bunch!!!) 4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too. 5. Clean the filter assembly. 6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well) 7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp 9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free. 8. Remove the Torx screw that holds that is the center just under the filter screen. 9. Pull the pump forward. 10. Unclamp the pump outlet hose. 11. Remove pump 12. Unclamp the large bellow on the pumps inlet and inspect for debris. 13. Clean pump and fitler w/o getting water on the pump. 14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer |
If you crack open slowly, the plastic grip handle while holding the nozel of a shop vac next to it, the slow drain of your washer will get sucked up into your vac.
I had to fill the washer up again and learned this tip after cleaning up all the water from putting around 12 towels out the first time. Barley any water on the floor using the shop vac. Just don't rush to open the grip handle and have the water spill out too quickly. |
| Display Modes | |
| Kenmore HE 2 plus error code F 28 | msruede | Washer Repair | 2 | 08-04-2010 08:45 AM |
| Kenmore HE2 Plus Error code F30 | mikerampino@yahoo.com | Washer Repair | 4 | 10-15-2009 04:50 AM |
| Kenmore HE3 with F02 Error Code | AC_73098 | Washer Repair | 3 | 07-15-2009 08:42 AM |
| Kenmore Washer Error Code | allezmont | Washer Repair | 1 | 06-06-2009 10:48 AM |
| Kenmore E0 F2 error code | rjdoss | Oven Repair (including Ranges and Cooktops) | 1 | 12-07-2008 06:59 AM |
