Discuss
Kent
 in
Washer Repair
My Neptune washer gets no hot water, filter screen is clear, I do get hot water to this point. Could
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kent
  #1 (permalink)
Old 12-13-2010, 02:52 PM
Junior Member
kent waring is on a distinguished road
Default Kent
Model Number: MAH4000 AWW   Brand: Maytag   Age: 5 - 10 years
My Neptune washer gets no hot water, filter screen is clear, I do get hot water to this point. Could it be the water dispenser valve?
Ads By Google
Related Models
Maytag MAH4000AWQ Washer - Horizontal Axis
Maytag MAH4000AWW Washer - Horizontal Axis
Maytag MAH4000BWQ Washer - Horizontal Axis
Maytag MAH4000BWW Washer - Horizontal Axis
Maytag MAH5500AWQ Washer - Horizontal Axis
Maytag MAH5500AWW Washer - Horizontal Axis
Maytag MAH5500BWQ Washer - Horizontal Axis
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
  #2 (permalink)
Old 12-14-2010, 03:03 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for MAH4000 AWW models | AppliancePartsPros.com
This should help it covers a number of Neptune models
16010061 Maytag Neptune Front Load Washer Service Manual - ApplianceDigest.com
You may have to join the site but it is free and it is a good site for a DIYer.
Yes it could.
Swap the wires for the hot and cold valves.
Now give it a try if you now get hot water into the unit your problem is else where.
OR
You could just check it with a meter to see if the coil has continuity, if not it is toast. I do this first as it is sefer than a live test.
If it has continuity then check if it is getting voltage (120 volts AC) when it should. If it does have voltage but will not open it is toast.
__________________
  #3 (permalink)
Old 12-15-2010, 04:27 AM
Junior Member
Default
I switched the wires and I got hot water in the washing machine, exactly what does that mean? I am capable of using testers and I will but I'm trying to pin point what part to buy. Appreciate your help, let me know.
  #4 (permalink)
Old 12-15-2010, 05:30 AM
Senior Expert
APP Volunteer
Default
It tells you that the hot valve itself is OK.
Since you knew that the cold was working you knew that the machine is giving voltage to the cold. Now you know that the hot valve will open when voltage is applied so the valve itself must be OK.
Therefore the machine cannot be giving voltage to open the hot valve.
Put the wires back where they should be.
Then try the diagnostics (last manual in the download) to see if you can force the hot water valve to open.
If it opens then the problem is probably on the control board.
Check the board for any signs of overheating or damace.
If it does not open.
Unplug the unit and check that the wires to the hot valve have continuity.
Undo both wires and check the wire:
WH11 has continuity to WH11 on the cold valve.
OR7 has continuity to P7 pin 1 on the Control Board.
Check the thermistor by disconnecting P2 on the control board and then measuring between pins 5 and 6.
For the life of me I could not find any info in the manuals as to what it should be. I am guessing around 10,000 ohms at room temperature.
As temperature rises resistance drops on these devices.
My thinking is that perhaps the unit thinks the water is already very very hot and therefore is not opening the hot valve.
I will do more searching to see if I can find/confirm what the resistance should be.
__________________
  #5 (permalink)
Old 12-15-2010, 05:37 AM
Senior Expert
APP Volunteer
Default
I may be out to lunch on the thermistor values.
Here is a chart of the thermistor used by Whirlpool in a Calypso washer
http://www.applianceaid.com/pictures/Calypso77.JPG
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
