| » Washer not agitating under some cycles |
Model Number: WTW5821SW0 Brand: Whirlpool Age: 1 - 5 years
If I run the regular wash cycle, the washer fills with water to the appropriate level, but does not advance to the agitation cycle. If I move the timer manually, the water drains from the washer properly.
If I run the rinse portion of the quick wash cycle, the washer fills with water to the appropriate level, agitates, and engages the draikn cycle. HOWEVER, although the washer drain is opened for the water to go out, the washer does not spin until I open and close the top once. Does this sound like a timer issue? Or is there something else I should consider replacing, such as the circuit board? Ads By Google Related Models |
| Display Modes | |
| Ge Profile Washer Agitating!! HELP!! | cgirl358 | Washer Repair | 3 | 12-11-2009 05:39 AM |
| GE Washer Not Agitating | penninger7142 | Washer Repair | 2 | 05-07-2009 09:47 PM |
| Washer not agitating | dalmorloson | Washer Repair | 1 | 09-06-2008 03:51 AM |
| washer not agitating | Kathy Sanchez | Washer Repair | 1 | 03-17-2008 08:25 PM |
| Washer not agitating | Todd | Washer Repair | 1 | 09-18-2007 01:45 AM |
