| » Leaky Kenmore Front Load Washer |
Model Number: 41741042000 Brand: Kenmore Age: 5 - 10 years
My washer began leaking 2 year ago at which time a repair tech came and tightened the bolts around the drum. He said at the time that the seals probably needed to be replaced but this was a huge job and he would have to take the whole washer apart. Anyway, we never had any problems until recently when it began leaking again. I tried tightening these bolts myself and it has helped considerably but it still leaks a little right from the joint where the two peices meet. I also noticed that one of the shock absorbers is broken which explains why it vibrates like a helicopter!
Should I replace the shock and hope that will inturn help vibration and hence not leak?? or should I also replace the drum seal or is that really a "huge job" like he said it was Ads By Google Related Models |
You definately need to replace the shock, the seal should probably also be replaced. It is a bigger job, but can be done as well.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
This probably isn't like your model but should give you the jest on how to do the repair, since your washer was made by Frigidaire. If this doesn't come thru send me an email and I'll email the manual to you.
http://www.frigidaire.com/tip/servic...5995393138.pdf Nat
__________________
| Display Modes | |
| Kenmore Front Load Washer Won't Run | nsmslf4 | Washer Repair | 0 | 02-09-2010 07:11 AM |
| Kenmore Front Load Washer 4Ht | hvaliquette | Washer Repair | 1 | 02-12-2009 03:39 AM |
| Leaky drum on Kenmore front load washer | dave1131 | Washer Repair | 0 | 01-12-2009 02:48 AM |
| kenmore front load washer | mattsea | Washer Repair | 1 | 01-11-2009 02:29 PM |
| leaky frigidaire front load washer | ronffall | Washer Repair | 1 | 10-27-2008 01:16 PM |
