| » Spin cycle |
Model Number: LAT8406AAE Brand: Maytag Age: 5 - 10 years
When I open the lid during the spin cycle the tub does not brake to a stop. It just spins until it naturally comes to a stop.
Quote:
If you have small children in the house this could be a problem. If they stuck their arm inside while it was still spinning, well, you know. Beyond that, as long as the unit is washing ok I dont see a problem with it.
__________________
Mr. Appliance of Lawton www.mrappliance.com/lawton |
Quote:
Thanks for the note, I would really like to know if the problem I have is due to the wiring of the motor or does it have something to do with the brake mechanisum. How do I troubleshoot the problem. |
When the brakes fail the tub will spin during wash and if this is the case the brake is bad and you need to get it repaired because this can cause problems. But if the tub is not spinning during wash then it is likely the brake isn’t the problem. There is a bearing under the large pulley that could the your problem. When the motor stops the brake is supposed to engage itself. When the brake engages the pulley spins backward but if the bearing is bad the pulley will not spin backward freely therefore the brakes will not engage. But during wash the motor forces the brakes to engage essentially un-sticking the pulley. The little bearing is cheap and easy to fix so if that is the problem I would go ahead and replace it.
Clothes Washer Repair Guide |
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| washer makes grinding noise and won't spin on spin cycle | marine1969 | Washer Repair | 1 | 08-30-2010 07:19 PM |
| motor, belt & trans pully spin, no agitation/spin cycle | slavens | Washer Repair | 2 | 05-08-2010 04:10 PM |
| Washer will not go through rinse or spin cycle on regular cycle | dhilde7165 | Washer Repair | 0 | 02-14-2009 04:10 PM |
| Maytag wash won't spin on regular cycle but will on gentle cycle | BlazingSun | Washer Repair | 0 | 01-07-2009 08:41 PM |
