Discuss
washer won't spin
 in
Washer Repair
The washer basin will not spin and drain water. The motor is spinning and the gearbox output is also spinning.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't spin
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-08-2007, 06:17 AM
dmcleer dmcleer is offline
Junior Member
dmcleer is on a distinguished road
Default washer won't spin
Model Number: TAWS700EQ2   Brand: Estate   Age: 5 - 10 years
The washer basin will not spin and drain water. The motor is spinning and the gearbox output is also spinning. There is a silver disc/wheel that spins and gets very hot. I notice the brake seems to be engaging/disengaging, but not sure why basket won't turn.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-09-2007, 02:14 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You probably have something stuck in the tub, just shine a lite in there to check.If so, you will need to pull spin basket. Also the plastic filter under basket sometimes drags on the bottom of the tub.
If everything ok there, you probably have dragging brake shoes. Pull motor and t and turn tranny coupler clock wise. If hard to turn this confirms bad brake shoes.Remove tranny.
Pry down spin tube enough to clear brake shoes from housing and remove and replace. Just call Appliancepartspros for part #.
__________________
  #3 (permalink)
Old 10-09-2007, 06:44 PM
Junior Member
Default
Thanks for the info. Where/how exactly do I pull the basket to check if something is stuck in it?
  #4 (permalink)
Old 10-10-2007, 01:54 AM
Senior Expert
APP Volunteer
Default
Pull outer cover from washer,remove plastic tub top and agitator. you will see a aluminum nut. It is a right hand thread, just turn counterclockwise with a short pipe wrench. I put the nut on half way and pound on it to break loose the basket.
__________________
  #5 (permalink)
Old 10-11-2007, 06:47 PM
Junior Member
Default
okay, I pulled the spin basket, and found the shaft spins just fine, without the basket on it. Also i didn't have to pull the aluminum nut off the nasket just came off pretty easily. The problem as I see it, the shaft spins, but the basket slips. The shaft spins and the basket sits still. As a temp fix I wrapped the shaft with some duct tape, and it is working for now, but it won't last forever. Does the aluminum nut close the split collar around the shaft, causing the required friction to turn the basket?
  #6 (permalink)
Old 10-12-2007, 01:24 AM
Senior Expert
APP Volunteer
Default
You probably need a new drive block that mounts on top of the spin tube. Also, did you check the filter under the spin basket. Sometimes they break and jam under the spin basket and hit the tub bottom.
__________________
  #7 (permalink)
Old 10-12-2007, 05:05 AM
Junior Member
Default
What does the spin block look like? The filter was kind of nasty and falling apart in places, but I don't believe that is the problem. I notice two tines sticking off the top of the drive shaft, do they do anything?
  #8 (permalink)
Old 10-12-2007, 06:16 AM
Senior Expert
APP Volunteer
Default
The drive block is slid over the end of the spin tube that drives the spin basket and the nut screws onto. There are slots in this drive block that slip into these spin tube spines and prevent it from spinning. You will probably need a new drive block.
__________________
  #9 (permalink)
Old 10-12-2007, 05:48 PM
oldman60 oldman60 is offline
Junior Member
oldman60 is on a distinguished road
Default
hi guys!
i got the almost exact same symptoms with my whirlpool.drivin me nuts!i still dont fathom how the clutch works!here's a pic of parts.why does the yelow nylon brake release have that funny little tang and slot?what is that little hook shaped wire for?somethimes when i put it all together it spins(if i try agitate first) and when i release the lid switch it stops on a dime!!then if i hit switch again motor goes and clutch drum spins but nuthin happens with tub!would it stop on a dime if tub drive block was shot?
  #10 (permalink)
Old 10-13-2007, 10:42 AM
Junior Member
Default
where do i get a drive block?, and how do i get the nut off. I can't get any leverage. I can't get it to budge at all.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin chevy2 Washer Repair 6 03-10-2008 12:47 PM
Washer will not spin Darren Washer Repair 4 10-26-2007 01:41 PM
washer won't spin Craig Washer Repair 1 09-30-2007 08:33 PM
Washer won't spin arnoldte Washer Repair 1 09-19-2007 09:04 PM
my washer won't spin jopas213 Washer Repair 5 08-21-2007 02:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
