| » washer won't spin |
i now understand the clutch operation.it is designed to slip and when worn it slips too easily.you can temp fix by increasing spring pressure by stretching spring slightly about 1/4 inch.also make sure no oil or grease is inside clutch drum.i am now working on finding suitable clutch pad material replacements as they are simply riveted on and can be changed.
The clutch assembly is available Pn 285785. Make sure the brake shoes aren't dragging or you will wear the clutch out again. Also the basket drive block is available Pn. 389140
__________________
| Display Modes | |
| my washer won't spin | jopas213 | Washer Repair | 8 | 10-23-2008 01:03 PM |
| washer will not spin | chevy2 | Washer Repair | 6 | 03-10-2008 01:47 PM |
| Washer will not spin | Darren | Washer Repair | 4 | 10-26-2007 02:41 PM |
| washer won't spin | Craig | Washer Repair | 1 | 09-30-2007 09:33 PM |
| Washer won't spin | arnoldte | Washer Repair | 1 | 09-19-2007 10:04 PM |
