Discuss
Washer will not agitate
 in
Washer Repair
First thing I found when I opened front control panel was that small glass fuse was burned. I replaced fuse
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not agitate
  #1 (permalink)
Old 11-19-2008, 07:49 AM
Junior Member
dveljko is on a distinguished road
Unhappy Washer will not agitate
Model Number: Maytag LAT8204AAE   Brand: Maytag   Age: 5 - 10 years
First thing I found when I opened front control panel was that small glass fuse was burned. I replaced fuse and machine started to fill water. Once water level was reched, water valve closed and nothing happened till timer reached last spin and pumped water out.
Ads By Google
Related Models
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Maytag MBF2256KEB2 REFRIGERATOR
Maytag MBF2256KEB3 REFRIGERATOR
  #2 (permalink)
Old 11-19-2008, 08:50 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Did it spin, or just pump out? Did you hear motor noise? Check for broken belt(s).
  #3 (permalink)
Old 11-19-2008, 08:57 AM
Junior Member
Emmett Talley is on a distinguished road
Default
it didnt spin
  #4 (permalink)
Old 11-19-2008, 08:59 AM
Junior Member
Default kenmore washing machine
it didnt spin in the spin cycle
  #5 (permalink)
Old 11-19-2008, 09:03 AM
Junior Member
Question
Quote:
  #6 (permalink)
Old 11-19-2008, 10:36 AM
Junior Member
Default
It did spin when pump was pumping water out.
  #7 (permalink)
Old 11-19-2008, 11:07 AM
Senior Expert
APP Volunteer
Default
Could be (from least expensive to most expensive):Worn or broken belts; Bad lid switch assembly; Bad Timer; Bad motor; Bad transmission.
  #8 (permalink)
Old 11-19-2008, 11:16 AM
Junior Member
Default
I eleiminated belts and motor since motor was spining and pumping and water out. This motor have two belts one for wash and one for pump. After water level reched set level, machine did not made any noise besides timer running. Timer passed first rince and did not pump water out. It was just turning (without motor agitating or making any noise) till reached the point when needed to spin and drain water. When it was spining i opened the lid and motor stoped. I closed the lid and machine finished spining and pumping water out.
  #9 (permalink)
Old 11-19-2008, 12:11 PM
Senior Expert
APP Volunteer
Default
That eliminates the lid switch and the motor. Possible bad timer or bad transmission. Timers fail more often and cost quite a bit less. If you're handy with hand tools, replacing the timer is well within your ability.
  #10 (permalink)
Old 11-19-2008, 02:25 PM
Junior Member
Default
I was going to check timer to see if it is sending connection to the motor. Do you know what pins should have connection when machnine is washing (agitating)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Won't Agitate MOSQUITO BITE Washer Repair 17 01-15-2010 05:30 AM
stackable washer dryer: washer will not agitate jennypatterson Dryer Repair 0 03-04-2009 11:08 AM
Washer does not agitate wackypackages Washer Repair 2 12-01-2008 03:55 PM
GE washer won't agitate lisav31 Washer Repair 8 07-29-2008 01:40 PM
Washer doesn't agitate dpuccetti Washer Repair 1 04-29-2008 02:00 AM
