Discuss
GE Washer Will Not Agitate Or Spin
 in
Washer Repair
The washer will fill and drain. Ohm checked the lid switch ok. Ohm checked the fuse ok. The belt is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer Will Not Agitate Or Spin
  #1 (permalink)
Old 12-10-2010, 10:36 AM
Junior Member
35mastr is on a distinguished road
Default GE Washer Will Not Agitate Or Spin
Model Number: WJRE555OHOWW   Brand: GE   Age: 1 - 5 years
The washer will fill and drain. Ohm checked the lid switch ok. Ohm checked the fuse ok. The belt is on. The motor never spins to agitate or for spin cycle. Drum pulley is free and also the motor. Both can be turned freely by hand. Tryed to check for codes under drip sheild on motor. But there is no led light as indicated on schmatic. Even pulled motor and pulled drip shield to find the LED. I dont see one on the board at all. Wife been without a machine all week. I really need to get this fixed. Please help me if all possible.
Thanks in advance.
Ads By Google
Related Models
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" Electric Range Ceran Cooktop
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
General Electric WKSE6280B1WW Washer
General Electric WKSE6280B2WW Washer
General Electric WKSE6280B3WW Washer
General Electric WKSR2100T2AA Washer
General Electric WKSR2100T2WW Washer
General Electric WKSR2100T3AA Washer
General Electric WKSR2100T3WW Washer
General Electric WKSR2100T5AA Washer
General Electric WKSR2100T5WW Washer
General Electric WKSR2100T6AA Washer
General Electric WKSR2100T6WW Washer
General Electric WKSR2100T8AA Washer
General Electric WKSR2100T8WW Washer
General Electric WKSR2100T9AA Washer
General Electric WKSR2100T9WW Washer
General Electric WKSR2100TAAA Washer
General Electric WKSR2100TAWW Washer
__________________
George
  #2 (permalink)
Old 12-10-2010, 11:03 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Unplug your machine. Find the motor wiring harness (left-most as you view the motor, facing the wire connectors) with the white w/red stripe wire in it. disconnect that connector. do a continuity check between that wire and the neutral blade of the machine's power cord. If no continuity, the fuse is bad.
  #3 (permalink)
Old 12-10-2010, 12:18 PM
Junior Member
Default
Quote:
Magicman, I have continuty there on that wire and the neutral on the plug.
Still no agitation or spin.
What would be the next step?
__________________
George
  #4 (permalink)
Old 12-10-2010, 12:37 PM
Senior Expert
APP Volunteer
Default
Same connector: Lid of the machine down. You should find continuity between the orange wire in the connector and the line, or, "hot" blade on the cord. It should open when you open the lid.
If no continuity with the lid down, replace the lid switch.
  #5 (permalink)
Old 12-10-2010, 12:59 PM
Junior Member
Default
Majicman,No Orange in that plug. Left to right I have 4 wires
Green with yellow tracer
White with red tracer
Red with black tracer
Last wire is either green or grey.
In the last wire I have continuity with lid down and open with lid up.
__________________
George
  #6 (permalink)
Old 12-10-2010, 01:31 PM
Senior Expert
APP Volunteer
Default
OK. You eithe rhave a bad timer or the motor is bad. Timers fail more frequently than motors. If you have a wiring diagram with your achine (most GEs don't have them), you may be able to do some voltage tests to determine which; but by the numbers, it's the timer.
Part number: AP4380181
  #7 (permalink)
Old 12-10-2010, 06:41 PM
Senior Member
applianceman is on a distinguished road
Default
If the LED isn’t flashing then the motor is most likely the problem. The control (timer/main board) will not cause the LED to go out. Now no LED may just be a coincidence, it could have been out for a while but generally if the LED isn’t flashing and the fuse isn’t blown the motor is the problem. Make sure you have power to the motor by testing from the red/black wire to the white/red wire; you should have 110 anytime the washer is plugged in.
Now put the washer into high-speed spin mode. There should be a red plug on the far right of the motor. With the washer in spin there should be 12 VDC between pins 5 (pin farthest right it should be purple) to pin 3 (third from left blue) and 12 VDC from pins 5 to pin 4 (forth from left black). If the voltages are good and the motor will not run the motor is bad. If you are not getting the correct voltage replace the control.
HydroWave GE Washer Repair Guide
  #8 (permalink)
Old 12-11-2010, 07:31 AM
Senior Expert
APP Volunteer
Default
Hey Applianceman:
I was getting some of my info from your website. You got a manual available on this generation of machine?
  #9 (permalink)
Old 12-11-2010, 08:05 AM
Senior Member
Default
All the manuals I have a paper manuals but if you go to http://appliancejunk.com/forums/
Or
Download Manager - ApplianceDigest.com
If you to go the GE forum on applinaceJunk and look at any washer thread. JW has posted a link to a manual on almost every GE washer thread. They regularly post manuals for this washer but I have never looked at them because I have the paper manuals. I have answered on a lot of those threads as well (screen name ryan111).
On the pages I wrote on my website I have tried to simplify the info but I don’t have all the info that is in the manual, only the things I believe most people will need to know (from experience in the field) . I am thinking about putting up another page that digs deeper on testing voltages on the motor like what I posted on this thread so that people with more electrical testing skills can confirm that it is the motor vs. control.
  #10 (permalink)
Old 12-11-2010, 10:12 AM
Junior Member
Default
I have 12VDC between 3 and 5. Also have 12VDC at 4 and 5. So I guess its safe to say that the motor is bad as it still never starts up.
I appretiate all the help that I get from this forum.
__________________
George
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Ge Washer Won't Agitate/Spin cus70 Washer Repair 3 01-13-2011 10:08 AM
Washer will not spin or agitate Legatus Washer Repair 1 11-26-2010 08:01 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
RCA Washer will not spin or agitate huffmanrq Washer Repair 0 11-18-2007 08:22 AM
