Discuss
Matag Epic Z shuts off after pressing start button
 in
Washer Repair
It also appears that the CCU has numerous part numbers. So far I have found 4 that appear to be
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Matag Epic Z shuts off after pressing start button
  #21 (permalink)
Old 11-02-2013, 08:53 PM
Junior Member
Dblboinger is on a distinguished road
Default Maytag CCU
It also appears that the CCU has numerous part numbers. So far I have found 4 that appear to be compatible with this machine (W10246302, W10205976, W10205839 and W10525356). Can you verify this is correct?
  #22 (permalink)
Old 11-04-2013, 07:23 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by Dblboinger View Post
Joe...did you mean 9-10k ohms? That is what my sensor measures and I can se the value change if you submerge it in warm (reading decreases) or cold water (reading increases).
Dblboinger, You're correct, I guess I forgot to add the K ohms to the previous post. Your resistance readings in general are correct, the resistance should increase as the water temperature is cool, and decrease as the water temperature increases. Now you need to do the same test at the wire harness connector at the TH2 terminal on the CCU. (You may need to insert a metal paper clip, large needle or pin into the connector to test the readings at the harness connector. If you get the same results, this will tell you the sensor and wire harness are operating properly, and you will need the CCU
W10525356
Part number: AP5781703
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas dryer won't start when pressing start button jimamy Dryer Repair 1 09-13-2010 03:28 PM
washer shuts off when pressing start martomic Washer Repair 0 09-09-2010 09:33 AM
when you press the on/off button then try turn it on by pressing hi/lo/med, it beeps boston5911 Oven Repair (including Ranges and Cooktops) 2 07-13-2010 07:34 PM
Dryer starts when door closed without pressing start mightymoe Dryer Repair 1 10-26-2008 05:50 PM
Odd Sound after Pressing Start RC55 Microwave Repair 9 06-04-2008 03:31 PM
