Discuss
Problem with cold water fill hose on washing machine.
 in
Washer Repair
Just recently the fitting (from hose to tap) broke off because of corrosion. Today I went and bought a new
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Problem with cold water fill hose on washing machine.
  #1 (permalink)
Old 12-09-2010, 01:07 AM
Junior Member
Need2WashMyClothesplzthx is on a distinguished road
Unhappy Problem with cold water fill hose on washing machine.
Model Number: Simpson 707   Brand: -other-   Age: More than 10 years
Just recently the fitting (from hose to tap) broke off because of corrosion. Today I went and bought a new fitting, cut out the old one and put it in along with a new washer. Feeling pretty proud of myself I screwed it back on the tap, started a cycle only to find it wouldn't start. So I started a hot cycle and it worked fine. The problem must be with the cold fill hose then? Prior to the fitting breaking the hose worked fine and was not clogged or anything, so I think it must be to do with the fitting I put on, but it looks exactly the same as the one on the hot water tap.
It seems like there is a small leak in the fitting that I put on because it drips, (only a small amount) but I wouldn't think this would stop the washing machine from filling?
Any ideas about what the problem is? I wanted to test if the cold water was flowing into the hose to see if it was a problem with the machine, but I don't see a way to take the hose off of the back of the machine, it's a very old unit and does not screw off like modern ones, and I did not want to cut it off because I see no way to put it back on.
Thanks in advance for any help !
Ads By Google
Related Models
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Amana SL25MW Ref - SXS/I&W
Amana SLD22JB Ref - SXS/I&W
Amana SLD22MB2L Ref - SXS/I&W
Amana SLD22MB2W Ref - SXS/I&W
Amana SLD22MBG Ref - SXS/I&W
Amana SLD22MBL Ref - SXS/I&W
Amana SLD22MBW Ref - SXS/I&W
Amana SLD25J Ref - SXS/I&W
Amana SLD25JB Ref - SXS/I&W
Amana SLD25JP Ref - SXS/I&W
Amana SLD25M2G Ref - SXS/I&W
Amana SLD25M2L Ref - SXS/I&W
Amana SLD25M2W Ref - SXS/I&W
Amana SLD25MB2L Ref - SXS/I&W
Amana SLD25MB2W Ref - SXS/I&W
Amana SLD25MBG Ref - SXS/I&W
Amana SLD25MBL Ref - SXS/I&W
Amana SLD25MBW Ref - SXS/I&W
Amana SLD25MG Ref - SXS/I&W
Amana SLD25ML Ref - SXS/I&W
Amana SLD25MP2L Ref - SXS/I&W
Amana SLD25MP2W Ref - SXS/I&W
Amana SLD25MPG Ref - SXS/I&W
Amana SLD25MPL Ref - SXS/I&W
Amana SLD25MPW Ref - SXS/I&W
Amana SLD25MW Ref - SXS/I&W
  #2 (permalink)
Old 12-11-2010, 05:29 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I am going to be of limited help because I cannot visualize your problem, but here is what I would suggest.
I assume you cannot easily remove the hose from the tap. If not, I would cut the hose in the middle, making sure you had connectors and clamps to splice it back together. You can now see if the cold water is flowing. I expect it will be so, and you will end up changing the valve assembly but before you do that make sure you are getting power to the valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No cold water in washing machine bandcamp Washer Repair 0 09-18-2010 07:41 AM
wahing machine wont fill on warm or cold water Mickey Spurgin Washer Repair 1 02-14-2010 12:57 PM
Washing machine does not fill up with water Eddiedean Washer Repair 1 01-29-2010 11:14 AM
cold water fill without machine on. ron baker Washer Repair 2 09-18-2009 06:40 AM
No Cold Water in Washing Machine Biskiii Washer Repair 1 04-06-2009 03:30 PM
