| » water pump will not work |
Model Number: mlg2000aww Brand: Maytag Age: 5 - 10 years
I have a maytag stackable washer and drier, model number mlg2000aww.
The water pump stoped working so i purchased another and installed. It does not pump. Ads By Google Related Models |
Quote:
Hana, When you replaced the drain pump, Did you check to see if the hoses were clogged or blocked with lint, etc. ? Do you hear the pump running when the machine is in the spin cycle ? Do you have a multi meter to test for 120 VAC from the control board to the drain pump ? Sorry to have more questions than answers, but we don't like to mis lead our subscribers. When you select the spin drain cycle, the first thing you should hear is the drain pump running. at that point a repairman would check for voltage on the wires to the drain pump. Your problem could be as simple as a loose / broken wire, or could be a failed control board circuit or timer. I don't think you'd have two bad pumps. You may want to re check the tub to pump hose and opening in the tub to make sure it's not blocked or plugged.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Check the motor coupling make sure its not cracked just a suggestion. w
Quote:
Please don't take this wrong, A MLG2000 stacked laundry system is a Maytag front load washer(MAH4000,Mah3000, etc) with a dryer stacked on top. These style units do not have a "motor coupling" the tumbler is belt driven, and the drain pump is an independant 120 VAC electric unit, driven by the control board. Just trying to help,
__________________
| Display Modes | |
| maytag dishwasher display lights work but pump not runing | mdg224 | Dishwasher Repair | 0 | 06-14-2010 05:14 PM |
| water not getting to hose from pump but water dispencer works not ice maker | sharbrat | Refrigerator & Freezer Repair | 0 | 07-29-2009 10:38 AM |
| will this pump also pump the drain water out | Paul Radovsky | Dishwasher Repair | 5 | 07-20-2008 01:41 PM |
| GE drain pump won't work | telesplicer | Washer Repair | 1 | 04-13-2008 06:11 PM |
| sock stuck in water pump... do i need a new pump? | volcompunker82 | Washer Repair | 0 | 03-08-2008 07:20 PM |
