Discuss
over fill
 in
Washer Repair
I ran a load on worm/cold . it failed to shut the cold water off and over flowed.is it a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » over fill
  #1 (permalink)
Old 12-06-2010, 07:50 PM
Junior Member
jim slade is on a distinguished road
Default over fill
Model Number: 11082874820   Brand: Kenmore   Age: More than 10 years
I ran a load on worm/cold . it failed to shut the cold water off and over flowed.is it a shut off switch or other.
Ads By Google
Related Models
Kenmore 11082874820 AUTOMATIC WASHER
Kenmore 11082874830 AUTOMATIC WASHER
Kenmore 11082880100 AUTOMATIC WASHER
Kenmore 11082880300 AUTOMATIC WASHER
Kenmore 11082880600 AUTOMATIC WASHER
Kenmore 11082880700 AUTOMATIC WASHER
Kenmore 11082880800 AUTOMATIC WASHER
Kenmore 11082881100 AUTOMATIC WASHER
Kenmore 11082881110 AUTOMATIC WASHER
Kenmore 11082881300 AUTOMATIC WASHER
Kenmore 11082881310 AUTOMATIC WASHER
Kenmore 11082881700 AUTOMATIC WASHER
Kenmore 11082881710 AUTOMATIC WASHER
Kenmore 11082881800 AUTOMATIC WASHER
Kenmore 11082881810 AUTOMATIC WASHER
Kenmore 11082882100 AUTOMATIC WASHER
Kenmore 11082882300 AUTOMATIC WASHER
Kenmore 11082882600 AUTOMATIC WASHER
Kenmore 11082882700 AUTOMATIC WASHER
Kenmore 11082882800 AUTOMATIC WASHER
Kenmore 11082883100 AUTOMATIC WASHER
Kenmore 11082883300 AUTOMATIC WASHER
Kenmore 11082883600 AUTOMATIC WASHER
Kenmore 11082883700 AUTOMATIC WASHER
Kenmore 11082883800 AUTOMATIC WASHER
Kenmore 11082884100 AUTOMATIC WASHER
Kenmore 11082884300 AUTOMATIC WASHER
Kenmore 11082884600 AUTOMATIC WASHER
Kenmore 11082884700 AUTOMATIC WASHER
Kenmore 11082884800 AUTOMATIC WASHER
Kenmore 11082891100 AUTOMATIC WASHER
Kenmore 11082891110 AUTOMATIC WASHER
Kenmore 11082891120 AUTOMATIC WASHER
Kenmore 11082891130 AUTOMATIC WASHER
Kenmore 11082891300 AUTOMATIC WASHER
Kenmore 11082891310 AUTOMATIC WASHER
Kenmore 11082891320 AUTOMATIC WASHER
Kenmore 11082891330 AUTOMATIC WASHER
Kenmore 11082891610 AUTOMATIC WASHER
Kenmore 11082891620 AUTOMATIC WASHER
Kenmore 11082891630 AUTOMATIC WASHER
Kenmore 11082891700 AUTOMATIC WASHER
Kenmore 11082891710 AUTOMATIC WASHER
Kenmore 11082891720 AUTOMATIC WASHER
Kenmore 11082891730 AUTOMATIC WASHER
Kenmore 11082891800 AUTOMATIC WASHER
Kenmore 11082891810 AUTOMATIC WASHER
Kenmore 11082891820 AUTOMATIC WASHER
Kenmore 11082891830 AUTOMATIC WASHER
Kenmore 11082892100 AUTOMATIC WASHER
Kenmore 11082892300 AUTOMATIC WASHER
Kenmore 11082892600 AUTOMATIC WASHER
Kenmore 11082892700 AUTOMATIC WASHER
Kenmore 11082892800 AUTOMATIC WASHER
Kenmore 11082979100 AUTOMATIC WASHER
Kenmore 11082979110 AUTOMATIC WASHER
Kenmore 11082979300 AUTOMATIC WASHER
Kenmore 11082979310 AUTOMATIC WASHER
Kenmore 11082979600 AUTOMATIC WASHER
Kenmore 11082979610 AUTOMATIC WASHER
Kenmore 11082979700 AUTOMATIC WASHER
Kenmore 11082979710 AUTOMATIC WASHER
Kenmore 11082979800 AUTOMATIC WASHER
Kenmore 11082979810 AUTOMATIC WASHER
Kenmore 11082980100 AUTOMATIC WASHER
Kenmore 11082980110 AUTOMATIC WASHER
Kenmore 11082980120 AUTOMATIC WASHER
Kenmore 11082980130 AUTOMATIC WASHER
Kenmore 11082980300 AUTOMATIC WASHER
Kenmore 11082980310 AUTOMATIC WASHER
Kenmore 11082980320 AUTOMATIC WASHER
Kenmore 11082980330 AUTOMATIC WASHER
Kenmore 11082980620 AUTOMATIC WASHER
Kenmore 11082980630 AUTOMATIC WASHER
Kenmore 11082980700 AUTOMATIC WASHER
Kenmore 11082980710 AUTOMATIC WASHER
Kenmore 11082980720 AUTOMATIC WASHER
Kenmore 11082980730 AUTOMATIC WASHER
Kenmore 11082980800 AUTOMATIC WASHER
Kenmore 11082980810 AUTOMATIC WASHER
Kenmore 11082980820 AUTOMATIC WASHER
Kenmore 11082980830 AUTOMATIC WASHER
Kenmore 11082982100 AUTOMATIC WASHER
Kenmore 11082982110 AUTOMATIC WASHER
Kenmore 11082982120 AUTOMATIC WASHER
Kenmore 11082982130 AUTOMATIC WASHER
Kenmore 11082982300 AUTOMATIC WASHER
Kenmore 11082982310 AUTOMATIC WASHER
Kenmore 11082982320 AUTOMATIC WASHER
Kenmore 11082982330 AUTOMATIC WASHER
Kenmore 11082982620 AUTOMATIC WASHER
Kenmore 11082982630 AUTOMATIC WASHER
Kenmore 11082982700 AUTOMATIC WASHER
Kenmore 11082982710 AUTOMATIC WASHER
Kenmore 11082982720 AUTOMATIC WASHER
Kenmore 11082982730 AUTOMATIC WASHER
Kenmore 11082982800 AUTOMATIC WASHER
Kenmore 11082982810 AUTOMATIC WASHER
Kenmore 11082982820 AUTOMATIC WASHER
Kenmore 11082982830 AUTOMATIC WASHER
Kenmore 11082983100 AUTOMATIC WASHER
Kenmore 11082983110 AUTOMATIC WASHER
Kenmore 11082983120 AUTOMATIC WASHER
Kenmore 11082983130 AUTOMATIC WASHER
Kenmore 11082983300 AUTOMATIC WASHER
Kenmore 11082983310 AUTOMATIC WASHER
Kenmore 11082983320 AUTOMATIC WASHER
Kenmore 11082983330 AUTOMATIC WASHER
Kenmore 11082983700 AUTOMATIC WASHER
Kenmore 11082983710 AUTOMATIC WASHER
Kenmore 11082983720 AUTOMATIC WASHER
Kenmore 11082983730 AUTOMATIC WASHER
Kenmore 11082983800 AUTOMATIC WASHER
Kenmore 11082983810 AUTOMATIC WASHER
Kenmore 11082983820 AUTOMATIC WASHER
Kenmore 11082983830 AUTOMATIC WASHER
Kenmore 11082984100 AUTOMATIC WASHER
Kenmore 11082984110 AUTOMATIC WASHER
Kenmore 11082984120 AUTOMATIC WASHER
Kenmore 11082984130 AUTOMATIC WASHER
  #2 (permalink)
Old 12-07-2010, 05:32 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for KENMORE 11082874820 | AppliancePartsPros.com
It depends how you were able to shut it off.
If you could stop it by turning the timer to off or unplugging the unit, then odds are that it is a water level switch problem.
If the only way to stop it was to turn off the tap., then it is a water valve problem. The valve is sticking open.
For A Water Level Switch
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
__________________
  #3 (permalink)
Old 12-07-2010, 06:30 PM
Junior Member
Default
I found the problem,it is the water valve. thank,s for the help,you have a new customer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not fill after replacing fill valve toddf Washer Repair 1 12-03-2010 12:39 PM
Maytag will fill only fill and nothign else tovar Washer Repair 2 06-06-2010 03:59 PM
no fill for wash but will fill for rinse CSM Dishwasher Repair 3 05-12-2009 12:13 PM
wont fill is it the fill valve acman727 Dishwasher Repair 1 03-14-2009 04:40 PM
Icemaker fill guide and fill tube freezing Cyberheater Refrigerator & Freezer Repair 6 02-05-2009 04:49 PM
