Discuss
Need Help.....
 in
Washer Repair
i have a fex831cso stackable and the water continues to fill the tub and not start its wash cycle, then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Need Help.....
  #1 (permalink)
Old 12-06-2010, 03:32 PM
Junior Member
roblee is on a distinguished road
Default Need Help.....
Model Number: FEX831CSO   Brand: Frigidaire   Age: 1 - 5 years
i have a fex831cso stackable and the water continues to fill the tub and not start its wash cycle, then overflows the tub, can you point me in the right direction?
Related Models
Frigidaire FEX831FS0 Frigidaire/laundry Center
Frigidaire FEX831FS1 LAUNDRY CENTER
Frigidaire FEX831FS2 LAUNDRY CENTER
Frigidaire FEX831FS4 LAUNDRY CENTER
Frigidaire FEZ831AS0 Lc - Frigidaire
Frigidaire FEZ831AS1 Lc - Frigidaire
Frigidaire FEZ831AS2 Frigidaire/laundry Center
Frigidaire FEZ831CFS0 Frigidaire/laundry Center
Frigidaire FEZ831CFS1 LAUNDRY CENTER
Amana FF105 REF - BOTTOM MOUNTS
Amana FF105A REF - BOTTOM MOUNTS
Amana FF105B REF - BOTTOM MOUNTS
Amana FF105L REF - BOTTOM MOUNTS
Amana FF105LA REF - BOTTOM MOUNTS
Amana FF105LB REF - BOTTOM MOUNTS
Amana FF125 REF - BOTTOM MOUNTS
Amana FF125A REF - BOTTOM MOUNTS
Amana FF125B REF - BOTTOM MOUNTS
Amana FF125L REF - BOTTOM MOUNTS
Amana FF125LA REF - BOTTOM MOUNTS
Amana FF125LB REF - BOTTOM MOUNTS
Amana FF15 FREEZER- VERTICAL
General Electric FF16DSARWH Refrigerator
General Electric FF16DSBRWH Refrigerator
General Electric FF16DSCRWH Refrigerator
General Electric FF16DSDRWH Refrigerator
General Electric FF16DSERWH Refrigerator
General Electric FF16DXARWH Refrigerator
General Electric FF16DXBRWH Refrigerator
General Electric FF16DXCRWH Refrigerator
General Electric FF20DSARWH Refrigerator
General Electric FF20DSBRWH Refrigerator
General Electric FF20DSCRWH Refrigerator
General Electric FF20DSDRWH Refrigerator
General Electric FF20DSERWH Freezers
General Electric FF20DXARWH Refrigerator
General Electric FF20DXBRWH Refrigerator
General Electric FF20DXCRWH Refrigerator
Amana FF98 REF - BOTTOM MOUNTS
Amana FF98A REF - BOTTOM MOUNTS
Amana FF98B REF - BOTTOM MOUNTS
Amana FF98L REF - BOTTOM MOUNTS
Amana FF98LA REF - BOTTOM MOUNTS
Amana FF98LB REF - BOTTOM MOUNTS
Frigidaire FFBD1821MB0A DISHWASHER
Frigidaire FFBD1821MS0A DISHWASHER
Frigidaire FFBD1821MW0A DISHWASHER
Frigidaire FFBD2403LB0A DISHWASHER
Frigidaire FFBD2403LB0B DISHWASHER
Frigidaire FFBD2403LS0B DISHWASHER
Frigidaire FFBD2403LW0A DISHWASHER
Frigidaire FFBD2403LW0B DISHWASHER
Frigidaire FFBD2405KB0 DISHWASHER
Frigidaire FFBD2405KB0A DISHWASHER
Frigidaire FFBD2405KS0 DISHWASHER
Frigidaire FFBD2405KS0A DISHWASHER
Frigidaire FFBD2405KW0 DISHWASHER
Frigidaire FFBD2405KW0A DISHWASHER
Frigidaire FFBD2407LB0A DISHWASHER
Frigidaire FFBD2407LB0B DISHWASHER
Frigidaire FFBD2407LM0A DISHWASHER
Frigidaire FFBD2407LM0B DISHWASHER
Frigidaire FFBD2407LQ0A DISHWASHER
Frigidaire FFBD2407LQ0B DISHWASHER
Frigidaire FFBD2407LS0A DISHWASHER
Frigidaire FFBD2407LS0B DISHWASHER
Frigidaire FFBD2407LW0A DISHWASHER
Frigidaire FFBD2407LW0B DISHWASHER
Frigidaire FFBD2409LB0A DISHWASHER
Frigidaire FFBD2409LM0A DISHWASHER
Frigidaire FFBD2409LQ0A DISHWASHER
Frigidaire FFBD2409LS0A DISHWASHER
Frigidaire FFBD2409LW0A DISHWASHER
Frigidaire FFC04M0AW1 Frigidaire/freezer
Frigidaire FFC0513D Frigidaire/freezer
Frigidaire FFC0522DW0 Frigidaire/freezer
Frigidaire FFC0522DW1 Frigidaire/freezer
Frigidaire FFC0522DW10 FREEZER
Frigidaire FFC0522DW11 FREEZER
Frigidaire FFC0522DW12 FREEZER
Frigidaire FFC0522DW13 FREEZER
Frigidaire FFC0522DW14 FREEZER
Frigidaire FFC0522DW15 FREEZER
Frigidaire FFC0522DW16 FREEZER
Frigidaire FFC0522DW17 FREEZER
Frigidaire FFC0522DW18 FREEZER
Frigidaire FFC0522DW19 FREEZER
Frigidaire FFC0522DW2 Frigidaire/freezer
Frigidaire FFC0522DW20 FREEZER
Frigidaire FFC0522DW3 Frigidaire/freezer
Frigidaire FFC0522DW4 Frigidaire/freezer
Frigidaire FFC0522DW5 Frigidaire/freezer
Frigidaire FFC0522DW6 Frigidaire/freezer
Frigidaire FFC0522DW7 FREEZER
Frigidaire FFC0522DW8 FREEZER
Frigidaire FFC0522DW9 FREEZER
Frigidaire FFC0522FW0 Frigidaire/freezer
Frigidaire FFC0522FW1 FREEZER
Frigidaire FFC0522FW2 FREEZER
Frigidaire FFC0522FW3 FREEZER
Frigidaire FFC0522FW4 FREEZER
Frigidaire FFC0522FW5 FREEZER
Frigidaire FFC0522FW6 FREEZER
Frigidaire FFC0522FW7 FREEZER
Frigidaire FFC0522FW8 FREEZER
Frigidaire FFC0522FW9 FREEZER
Frigidaire FFC0522GB0 Frigidaire/freezer
Frigidaire FFC0522GB1 FREEZER
Frigidaire FFC0522GB5 FREEZER
Frigidaire FFC0523DW0 Frigidaire/freezer
Frigidaire FFC0523DW1 Frigidaire/freezer
Frigidaire FFC05C2AW0 Frigidaire/freezer
Frigidaire FFC05C2AW1 Frigidaire/freezer
Frigidaire FFC05C3CW0 Frigidaire/freezer
Frigidaire FFC05C3CW1 Frigidaire/freezer
Frigidaire FFC05C3CW2 Frigidaire/freezer
Frigidaire FFC05C3CW3 Frigidaire/freezer
Frigidaire FFC05C4CW0 Frigidaire/freezer
Frigidaire FFC05K0AW0 Frigidaire/freezer
Frigidaire FFC05K0AW1 Frigidaire/freezer
  #2 (permalink)
Old 12-06-2010, 03:51 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
Yes, if you just hit the timer to shut the water of it is the water fill switch. If you had to shut the water off at the water spicket to shut the water off, you need a new water valve on the washer. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
  #3 (permalink)
Old 12-07-2010, 05:54 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Water level switch checks
This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate.
Possible problems.
1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug.
2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
Note: That you may be able to stop it by blowing into then tubing and it may still be no good as it needs too much pressure to activate the switch.
So iof the tubing is OK replace the switch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
