Discuss
loud noise
 in
Washer Repair
The washer work good but when it get to spin cycle it makes a loud noise and the washer will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » loud noise
  #1 (permalink)
Old 12-06-2010, 06:44 AM
Junior Member
ving71 is on a distinguished road
Unhappy loud noise
Model Number: WTW6600SW2   Brand: Whirlpool   Age: 1 - 5 years
The washer work good but when it get to spin cycle it makes a loud noise and the washer will stop. I need to open the lid to turn it back on and its doing it again.never finish the whole cycle the clothes are too wet to put it in the dryer. what part do i need to replace.
Ads By Google
Related Models
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 Dishwasher - Undercounter
Maytag WU200 Dishwasher - Undercounter
Maytag WU201 Dishwasher - Undercounter
Maytag WU202 Dishwasher - Undercounter
Maytag WU203 Dishwasher - Undercounter
Maytag WU204 Dishwasher - Undercounter
Maytag WU282 Dishwasher - Undercounter
Maytag WU284 Dishwasher - Undercounter
Maytag WU285 Dishwasher - Undercounter
Maytag WU300 Dishwasher - Undercounter
Whirlpool WU3000V0
Whirlpool WU3000V1
Whirlpool WU3000V2
Whirlpool WU3000V3
Whirlpool WU3000X0
Whirlpool WU3000X1
Whirlpool WU3000X2
Whirlpool WU3000X3
Whirlpool WU3000X4
Whirlpool WU3000X5
Whirlpool WU3000X6
Whirlpool WU3000Y0
Whirlpool WU3000Y1
Whirlpool WU3006V0
Whirlpool WU3006V1
Whirlpool WU3006V2
Whirlpool WU3006V3
Whirlpool WU3006X0
Whirlpool WU3006X1
Whirlpool WU3006X2
Whirlpool WU3006X3
Whirlpool WU3006X4
Whirlpool WU3006X5
Whirlpool WU3006X6
Whirlpool WU3006Y0
Whirlpool WU3006Y1
Maytag WU301 Dishwasher - Undercounter
Maytag WU302 Dishwasher - Undercounter
Maytag WU303 Dishwasher - Undercounter
Maytag WU304 Dishwasher - Undercounter
Whirlpool WU3050Y0
Whirlpool WU3050Y1
Whirlpool WU3056Y0
Whirlpool WU3056Y1
Maytag WU384 Dishwasher - Undercounter
Maytag WU400 Dishwasher - Undercounter
Maytag WU401 Dishwasher - Undercounter
Maytag WU404 Dishwasher - Undercounter
Whirlpool WU4300B0
Whirlpool WU4300B1
Whirlpool WU4300Y0
Whirlpool WU4300Y1
Whirlpool WU4300Y2
Whirlpool WU4300Y3
Whirlpool WU4300Y4
Whirlpool WU4400V0
Whirlpool WU4400V1
Whirlpool WU4400V2
Whirlpool WU4400V3
Whirlpool WU4400X0
Whirlpool WU4400X1
Whirlpool WU4400X2
Whirlpool WU4406V1
Whirlpool WU4406V3
Whirlpool WU4500B0
Whirlpool WU4500B1
Whirlpool WU4500Y0
Whirlpool WU4500Y1
Whirlpool WU4500Y2
Whirlpool WU4500Y3
Maytag WU482 Dishwasher - Undercounter
Maytag WU484 Dishwasher - Undercounter
Maytag WU490 Dishwasher - Undercounter
Maytag WU494 Dishwasher - Undercounter
Maytag WU500 Dishwasher - Undercounter
Maytag WU501 Dishwasher - Undercounter
Maytag WU502 Dishwasher - Undercounter
Maytag WU504 Dishwasher - Undercounter
Whirlpool WU5650V0
Whirlpool WU5650V1
Whirlpool WU5650V2
Whirlpool WU5650X0
Whirlpool WU5650X1
Whirlpool WU5650X2
Whirlpool WU5750B0
Whirlpool WU5750B1
Whirlpool WU5750Y0
Whirlpool WU5750Y1
  #2 (permalink)
Old 12-06-2010, 09:04 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Ving,
Which failure code(s) appear in the display, when this occurs ?
Based on your information and description, you may have; a bad drain pump, something stuck under the impeller plate, or bad tub bearing(outer tub assembly).
The failure codes, logged into the control memory, and displayed on the panel, will give us a better direction to take.
Your Technical Date Sheet, should be attached to the inside of the front panel,(you'll need to raise the top of the washer to access it) or you may find it inside the control panel on a newer model).
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-09-2010, 06:05 AM
Junior Member
Default
Quote:
Originally Posted by Joe / APP Team View Post
Ving,
hello, sorry I was too busy for the past days dont have the chance to check this forum. the failure code that appeared after the washer stop is uL.if the drain pump is the cause of this can you tell me the part number that i need to buy also with the tub bearing. It is difficult to repair or change these parts?
  #4 (permalink)
Old 12-09-2010, 08:16 AM
Senior Expert
Default
Ving,
The drain pump is a relatively, easy repair, in fact, you can check it, before you order the part,
Part number: AP4365341
Most technicians, slide the machine out far enough to lean the unit against the wall, and climb under it.
Otherwise you need to remove it far enough, to lay the washer on it's back.
There are two pumps on your unit, the drain pump and recirculation pump.
Removal is pretty much easy, disconnect the wire harness, disconnect the hoses, remove the mounting bolt and drop the pump.
Check the inlet and outlet openings for debris and clogs, etc.
You can also run the motor, if you have a 120 VAC test cord,
You could also disconnect the wires from the drain pump and run the spin/drain cycle, see if the noise is there, if not you, need the pump, if it's still there, we need to move on the the tub bearing, drive motor.
Basically, a complete tear down.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loud Noise! wonderful Washer Repair 0 08-01-2010 02:56 PM
Loud Noise hydrod Washer Repair 1 04-16-2010 06:26 PM
Loud fan noise? cfr Microwave Repair 1 07-29-2009 10:11 PM
loud noise newengland265 Dishwasher Repair 0 11-02-2008 10:00 AM
Loud Noise romeroom Dishwasher Repair 5 01-28-2008 12:22 PM
