| » Lg Washer Won't Wash |
Model Number: WM1832CW Brand: -brand- Age: 5 - 10 years
I have an LG washer with no power to motor I can turn the motor an tub. When I put it in washer the motor moves about a inch. It does this about 3 times an faults out as motor overload (LE). It has a stator sensor, stator assy., an a rotor assy. If any one can help me pinpoint what part is bad I would appreciate it. Thanks!
No one can point you in the right direction because even LG cannot deal with this problem.
The error message means that the hall sensor is not telling the control board that the motor is turning, so the control board shuts it down. This can be because of problems with the motor, hall sensor, wiring, or control board. I would thoroughly check the wiring because in many cases a short in the wiring harness to the control board is the problem.
__________________
| Display Modes | |
| Washer does not wash | seelamm | Washer Repair | 1 | 10-09-2010 06:41 PM |
| Washer Won't Wash or Spin | sara0303 | Washer Repair | 0 | 04-07-2010 11:37 AM |
| Washer wil not wash | esrica2 | Washer Repair | 1 | 05-31-2009 06:07 PM |
| washer won't wash | hlarson1974 | Washer Repair | 1 | 04-29-2009 06:23 PM |
| Washer not pumping at the end of wash but will pump on spin and lite wash. | rathbonr | Washer Repair | 0 | 07-16-2008 11:45 AM |
