Discuss
washer quit working
 in
Washer Repair
i have a kenmore he2+ that just stopped working.the fault codes suggest the ccu needs replacing.I am not sure if
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer quit working
  #1 (permalink)
Old 12-04-2010, 05:56 AM
Junior Member
paulgrot is on a distinguished road
Default washer quit working
Model Number: 11047532600   Brand: Kenmore   Age: 1 - 5 years
i have a kenmore he2+ that just stopped working.the fault codes suggest the ccu needs replacing.I am not sure if this is the board located on the top right hand side of washer or the one located on the bottom right side.Thanks for any imput.
Ads By Google
Related Models
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055594 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 11057624 KENMORE PERMANENT INSTALLATION CONV KIT
Kenmore 11057929 KENMORE DUAL AGITATOR KIT
Kenmore 1105809106 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809702 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809703 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809704 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809800 KENMORE GAS CONBINATION WASHER-DRYER
Kenmore 1105907400 KENMORE GAS DRYER
Kenmore 1105907500 KENMORE GAS DRYER
Kenmore 1105907501 KENMORE GAS DRYER
Kenmore 1105907600 KENMORE GAS DRYER
Kenmore 1105907610 KENMORE GAS-DRYER
Kenmore 1105907700 KENMORE GAS DRYER
Kenmore 1105907710 KENMORE GAS DRYER
Kenmore 1105907720 KENMORE GAS DRYER
Kenmore 1105907721 KENMORE GAS DRYER
Kenmore 1105907730 KENMORE GAS DRYER
Kenmore 1105907800 KENMORE GAS DRYER
Kenmore 1105907801 KENMORE GAS DRYER
Kenmore 1105907802 KENMORE GAS DRYER
Kenmore 1105907950 KENMORE GAS DRYER
Kenmore 1105907951 KENMORE GAS DRYER
Kenmore 1105908000 KENMORE ELECTRIC DRYER
Kenmore 1105908100 KENMORE ELECTRIC DRYER
Kenmore 1105908300 KENMORE ELECTRIC DRYER
Kenmore 1105908400 KENMORE ELECTRIC DRYER
Kenmore 1105908500 KENMORE ELECTRIC DRYER
Kenmore 1105908501 KENMORE ELECTRIC DRYER
Kenmore 1105908600 KENMORE ELECTRIC DRYER
Kenmore 1105908700 KENMORE ELECTRIC DRYER
Kenmore 1105908710 KENMORE ELECTRIC DRYER
Kenmore 1105908711 KENMORE ELECTRIC DRYER
Kenmore 1105908800 KENMORE ELECTRIC DRYER
Kenmore 1105908801 KENMORE ELECTRIC DRYER
Kenmore 1105908810 KENMORE ELECTRIC DRYER
Kenmore 1105908811 KENMORE ELECTRIC DRYER
Kenmore 1105908950 KENMORE ELECTRIC DRYER
Kenmore 1105908951 KENMORE ELECTRIC DRYER
Kenmore 1105908960 KENMORE ELECTRIC DRYER
Kenmore 1105909500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909501 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105909502 KENMORE GAS COMBINATON WASHER-DRYER
Kenmore 1105909503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105917200 KENMORE GAS DRYER
Kenmore 1105917400 KENMORE GAS DRYER
Kenmore 1105917500 KENMORE GAS DRYER
Kenmore 1105917510 KENMORE GAS DRYER
Kenmore 1105917600 KENMORE GAS DRYER
Kenmore 1105917620 KENMORE GAS DRYER
Kenmore 1105917630 KENMORE GAS DRYER
Kenmore 1105918400 KENMORE ELECTRIC DRYER
Kenmore 1105918500 KENMORE ELECTRIC DRYER
Kenmore 1105918600 KENMORE ELECTRIC DRYER
Kenmore 1105918620 KENMORE ELECTRIC DRYER
Kenmore 11060052990 DRYER/WASHER
Kenmore 11060052991 ELECTRIC DRYER
Kenmore 11060056990 ELECTRIC DRYER
Kenmore 11060056991 ELECTRIC DRYER
Kenmore 1106007101 KENMORE GAS DRYER
Kenmore 11060072990 DRYER
Kenmore 11060072991 ELECTRIC DRYER
Kenmore 1106007301 KENMORE GAS DRYER
Kenmore 1106007400 KENMORE GAS DRYER
Kenmore 1106007430 KENMORE GAS DRYER
Kenmore 1106007440 KENMORE GAS DRYER
Kenmore 1106007500 KENMORE GAS DRYER
Kenmore 1106007600 KENMORE GAS DRYER
Kenmore 1106007610 KENMORE GAS DRYER
Kenmore 1106007700 KENMORE GAS DRYER
Kenmore 1106007710 KENMORE GAS DRYER
Kenmore 1106007711 KENMORE GAS DRYER
Kenmore 1106007712 KENMORE GAS DRYER
Kenmore 1106007713 KENMORE GAS DRYER
Kenmore 1106007714 KENMORE GAS DRYER
Kenmore 1106007715 KENMORE GAS DRYER
Kenmore 1106007716 KENMORE GAS DRYER
Kenmore 1106007717 KENMORE GAS DRYER
Kenmore 1106007800 KENMORE GAS DRYER
Kenmore 1106007950 KENMORE GAS DRYER
Kenmore 1106008000 KENMORE ELECTRIC DRYER
Kenmore 1106008100 KENMORE ELECTRIC DRYER
Kenmore 1106008300 KENMORE ELECTRIC DRYER
Kenmore 1106008400 KENMORE ELECTRIC DRYER
Kenmore 1106008430 KENMORE ELECTRIC DRYER
Kenmore 1106008440 KENMORE ELECTRIC DRYER
Kenmore 1106008500 KENMORE ELECTRIC DRYER
Kenmore 1106008600 KENMORE ELECTRIC DRYER
Kenmore 1106008700 KENMORE ELECTRIC DRYER
Kenmore 1106008710 KENMORE ELECTRIC DRYER
Kenmore 1106008711 KENMORE ELECTRIC DRYER
Kenmore 11061062000 DRYER
Kenmore 11061064000 DRYER
Kenmore 11061066000 DRYER
Kenmore 1106107400 KENMORE GAS DRYER
Kenmore 1106107401 KENMORE GAS DRYER
Kenmore 1106107500 KENMORE GAS DRYER
Kenmore 1106107501 KENMORE GAS DRYER
Kenmore 1106107502 KENMORE GAS DRYER
Kenmore 1106107700 KENMORE GAS DRYER
Kenmore 1106107701 KENMORE GAS DRYER
Kenmore 1106107710 KENMORE GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer quit working dannyc Washer Repair 3 09-21-2010 02:21 PM
Quit working chasshoe Refrigerator & Freezer Repair 1 09-21-2010 06:26 AM
washer quit working dannyc Washer Repair 1 09-15-2010 11:53 AM
help washer quit working, possilbe the lid switch?? star1006 Washer Repair 1 07-09-2010 04:17 PM
Dish Washer quit working Nikita Smith Dishwasher Repair 0 10-08-2009 05:26 PM
