| » Washer will not drain or spin. |
Model Number: 110.22642100 Brand: Kenmore Age: 5 - 10 years
The washer fills and goes through the wash cycle but will not drain or spin. When manually turning the timer to spin it does nothing. The drain hoses are clear. The only thing odd that I noticed was the lid switch is always down and the belt looks loose and twisted. Please advise.
Quote:
You most likely have a damaged lid switch assembly, Part number: AP3100001 That's where, I would start you, The switch circuit will allow the washer to fill and wash, but it will not allow a spin / drain, if it's bad. Where is this loose, twisted belt located ? You have a "Direct Drive" washer(going by the model number you supplied) It has no drive belt, I'm wonderring if it may be the wiring harness for the lid switch assembly ?? Thanks and Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| Washer won't drain or spin | patsycreations | Washer Repair | 0 | 02-20-2009 10:21 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| washer will spin but not drain | bear801 | Washer Repair | 0 | 05-18-2008 08:50 AM |
