Discuss
Frigidaire washer leaking out bottom
 in
Washer Repair
Hello, I found lots of "leaking washing machines" on the forum but not quite the same as mine. The machine
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire washer leaking out bottom
  #1 (permalink)
Old 12-03-2010, 10:54 AM
Junior Member
firedancer is on a distinguished road
Question Frigidaire washer leaking out bottom
Model Number: FWX645LBS2   Brand: Frigidaire   Age: 5 - 10 years
Hello,
The machine is operating just fine as far as the water filling the tub, spin cycles, water pumping out, etc. It's a little squeaky (maybe ball bearings?), but no complaints. The issue is a water leak that shows up on the floor near the front right leg of the machine. This has been an intermittent problem - meaning it doesn't happen on every load - for a few months. But just last night, I noticed a puddle around the front left leg of the machine as well.
Could this be the tub seal? Or does it sound like another problem?
Thank you so much for your time!
Related Models
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970E FRIGIDAIRE WASHER
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971E FRIGIDAIRE WASHER
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975E FRIGIDAIRE WASHER
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Frigidaire FXP18B4AW0 REFRIGERATOR
Frigidaire FXP18B4AW1 FRIGIDAIRE/REFRIGERATOR
Hardwick G-433 SURFACE UNIT- ELE
Hardwick G-436 SURFACE UNIT- ELE
Hardwick G-445 SURFACE UNIT- ELE
Jenn-Air G0206B-8 ELECTRIC GRILL OUTDOOR
Jenn-Air G100 SURFACE UNIT- DDRAFT ELE
Jenn-Air G101 SURFACE UNIT- DDRAFT ELE
Jenn-Air G102 SURFACE UNIT- DDRAFT ELE
Jenn-Air G103 SURFACE UNIT- DDRAFT ELE
Admiral G1110PRA RANGE- F/S STD GAS
Admiral G1110PRW RANGE- F/S STD GAS
Frigidaire G12W
Frigidaire G15W
Frigidaire G18W
Whirlpool G20EFSB2313 REFRIGERATOR
Whirlpool G20EFSB23S4 REFRIGERATOR
Whirlpool G20EFSB23S5 REFRIGERATOR
Whirlpool G20EFSB23S6 REFRIGERATOR
Whirlpool G20EFSB23S7 REFRIGERATOR
Whirlpool G20EFSB23S8 REFRIGERATOR
Whirlpool G20EFSB23S9 REFRIGERATOR
Frigidaire G21CL0 Frg(v1) / Gas Range
Frigidaire G21CW0 Frg(v2) / Gas Range
Frigidaire G21CW2 Frg(v1) / Gas Range
Frigidaire G21CW3 Frg(v2) / Gas Range
Frigidaire G21PCL0 Frg(v1) / Gas Range
Frigidaire G21PCL1 Frg(v3) / Gas Range
Frigidaire G21PCL3 Frg(v2) / Gas Range
Frigidaire G21PCL4 Frg(v2) / Gas Range
Frigidaire G21PCL5 Frg(v4) / Gas Range
Frigidaire G21PCW0 Frg(v2) / Gas Range
Frigidaire G21PCW1 Frg(v4) / Gas Range
Frigidaire G21PCW3 Frg(v1) / Gas Range
Frigidaire G21PCW4 Frg(v1) / Gas Range
Frigidaire G21PCW5 Frg(v3) / Gas Range
Frigidaire G22W
Frigidaire G24CL0 Frg(v1) / Free Standing Gas Range
Frigidaire G24CL3 Frg(v2) / Gas Range
Frigidaire G24CL4 Frg(v4) / Gas Range
Frigidaire G24CW0 Frg(v2) / Free Standing Gas Range
Frigidaire G24CW3 Frg(v1) / Gas Range
Frigidaire G24CW4 Frg(v3) / Gas Range
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Whirlpool G25EFSB2313 REFRIGERATOR
Whirlpool G25EFSB23S4 REFRIGERATOR
Whirlpool G25EFSB23S5 REFRIGERATOR
Whirlpool G25EFSB23S6 REFRIGERATOR
Whirlpool G25EFSB23S7 REFRIGERATOR
Whirlpool G25EFSB23S8 REFRIGERATOR
Whirlpool G25EFSB23S9 REFRIGERATOR
Whirlpool G2IXEFMWB00 REFRIGERATOR
Whirlpool G2IXEFMWB01 REFRIGERATOR
Whirlpool G2IXEFMWB02 REFRIGERATOR
Whirlpool G2IXEFMWB03 REFRIGERATOR
Whirlpool G2IXEFMWQ00 REFRIGERATOR
Whirlpool G2IXEFMWQ01 REFRIGERATOR
Whirlpool G2IXEFMWQ02 REFRIGERATOR
Whirlpool G2IXEFMWQ03 REFRIGERATOR
Whirlpool G2IXEFMWS00 REFRIGERATOR
Whirlpool G2IXEFMWS01 REFRIGERATOR
Whirlpool G2IXEFMWS02 REFRIGERATOR
Whirlpool G2IXEFMWS03 REFRIGERATOR
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
  #2 (permalink)
Old 12-04-2010, 06:03 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Take off the front and operate the machine and you should be able to see the source of the leak. I think it is likely the pump or an internal hose.
__________________
  #3 (permalink)
Old 12-04-2010, 08:48 PM
Junior Member
Default
Sidfink - Thank you very much - I'll give that a shot!
  #4 (permalink)
Old 12-04-2010, 08:57 PM
Junior Member
finellic is on a distinguished road
Default Same problem, but different source
Quote:
I noticed this same problem tonight with my Frigidaire washer. I watched as the machine operated and noticed that the water is coming from the seam between the upper portion (splash cover) of the splash tub and the lower portion of the splash tub.
It looks like the splash cover has come loose and doesn't seal. I think the gasket has cracked as well. Do I need to replace the splash cover, or can I use caulk (or similar) to create a better seal. The washer is 11 years old, so a quick and dirty fix is probably fine.
Thanks.
Chris
  #5 (permalink)
Old 12-05-2010, 07:52 AM
Senior Expert
APP Volunteer
Default
Finellic
You can do whatever works, and after 11 years your machine doesn't owe you anything. Just make sure you are sealing the leak and no redirecting the water someplace else.
__________________
  #6 (permalink)
Old 12-14-2010, 07:05 PM
Junior Member
Default
Hey Chris - How did you get the front panel off? I've looked all over online and just keep finding how to disassemble the whole unit (starting with the back, then the sides, and THEN the front). Were you able to just take off the front panel?
Thanks in advance! I just don't want to bust something!
  #7 (permalink)
Old 12-14-2010, 07:18 PM
Junior Member
Default
If you've got a unit similar to mine, there are two screws at the bottom of the front panel. Remove them. The front panel is then held onto the top by two spring clips. You may be able to slide the front panel down, but you might need to use a flathead screw driver to get past the sping clips. The panel should come right off by sliding it down.
You still may have to remove the two screws holding the top onto the back to access the tub, but they don't affect your ability to get at the front panel.
Disclaimer: I'm not a repairman, just a tinker. These methods worked for my washer. Hopefully they'll work for yours.
Good luck.
Chris
  #8 (permalink)
Old 12-15-2010, 12:10 PM
Junior Member
Default
I figured out how to remove the front panel, and there's water coming out all around the tub at the top, which I assume means the tub seal has worn out. And there's another leak when it's pumping out the water. Is it worth it to fix the pump and tub seal myself? Or should we be looking at a new washing machine.
  #9 (permalink)
Junior Member
Default
Thanks for the help, Chris!!
  #10 (permalink)
Old 12-15-2010, 01:02 PM
Junior Member
Default
Hi Sidfink - It seems the source of the leak is at the top of the drum. There is water all around the outside of the drum. But after watching videos on replacing the tub seal I realized this is a part at the bottom of the drum, and that doesn't sound like my problem. What is the seal at the top of the drum called, and does this sound like it's the source of my problem?
Thanks for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Leaking from bottom zenny216 Dishwasher Repair 0 12-20-2009 08:53 PM
washer is leaking from the bottom mike35 Washer Repair 0 04-07-2009 04:38 PM
Washer leaking out the bottom mybrotherskpr Washer Repair 1 03-17-2009 07:29 AM
Washer Leaking from bottom. HELP! ashbranstad Washer Repair 2 12-30-2008 08:24 AM
washer is leaking out bottom mavmik Washer Repair 1 05-10-2008 05:46 PM
