Frigidaire will not stop filling
The unit does not stop filling regardless what size setting.
Your pressure switch maybe out ot the tube may have a crack, pin hole or water in it. Or your valve just stuck open.
Nat |
While it's filling, unplug the machine. If it continues to fill, the problem is the water inlet valve.
| All times are GMT -7. The time now is 02:20 PM. |
