Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Timer Knob Just Spins (http://forum.appliancepartspros.com/washer-repair/14801-timer-knob-just-spins.html)
jrann1 11-15-2008 03:39 PM
The timer know just spins whne I tried to put in a new load of laundry. It worked fine earlier in the day and now the know just spins, it is like it is not catching on anything. I also am unable to pull it out or push it in. Any idea what needs to be done to fix it???
:confused:
libertyappl 11-15-2008 04:09 PM
You will need to determine if it's the shaft in the timer or the knob itself that is messed up, timer part # AP2045964
Nat
jrann1 11-16-2008 06:08 AM
How do I get the know off to determine if it is the knob or the shaft that is ghaving the problem?? I took the screws out of the top so the face plate is free, but how do I get the know off to determine the problem?? Do I need a special tool or is there another way to get it off?
denman 11-16-2008 06:46 AM
Here is the parts breakdown
Model S3200Y1WW
Here is how it is held on
http://www.applianceaid.com/washerknobs.html
