Discuss
Maytag Washer
 in
Washer Repair
The washer overflowed and I had trouble getting it to shut off. I turned the water off at the source
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer
  #1 (permalink)
Old 11-29-2010, 08:15 AM
Junior Member
thomasasawyer is on a distinguished road
Default Maytag Washer
Model Number: LA612   Brand: Maytag   Age: More than 10 years
The washer overflowed and I had trouble getting it to shut off. I turned the water off at the source and eventually also unplugged the washer. I suspect the problem is the blue water valve unit on the back or the pressure/water level switch. I disconnected the house to the pressure swith at the switch itself and blew through it (it seemed to be clear, but I can't be sure -- I did not disconnect it at the base of the tub in the back because the tube is wider at that point and I did not want to possibly damage it without having a replacement on hand. Because the pressure swith in the control panel is almost $100.00 I think it's better if I only replace the water valve and the possibly the house to the pressure switch and see what happens -- the washer is nearly 20 years old, so if repair parts, etc. total well over $100.00 it may not be worth it and I'll buy a new washer. I located the Water Valve part (AP4023852), but can't find the hose...need help with this selection. I also located what I think is the correct Water Level/Pressure Swith (#AP4031099) in the event I decide to replace that unit. Any and all help would be appreciated, especially identifying the correct hose to get. THANKS. Tom S.
Ads By Google
Related Models
Maytag LA612 WASHER-TOP LOADING
Maytag LA612S WASHER-TOP LOADING
Maytag LA612T Washer - Top Loading
Maytag LA613 WASHER-TOP LOADING
Maytag LA613T Washer - Top Loading
Whirlpool LA6150XSW0
Whirlpool LA6150XSW1
Whirlpool LA6150XTF0
Whirlpool LA6150XTG0
Whirlpool LA6150XTG1
Whirlpool LA6150XTM0
Whirlpool LA6150XTN0
Whirlpool LA6150XTN1
Whirlpool LA6150XTW0
Whirlpool LA6150XTW1
Whirlpool LA6200XPW3
Whirlpool LA6200XSW0
Frigidaire LA625EXD3 Wwh(v16) / Top Loading Washer
Frigidaire LA625EXF3 Wwh(v17) / Top Loading Washer
Frigidaire LA625EXH3 Wwh(v18) / Top Loading Washer
Frigidaire LA625EXV3 Wwh(v19) / Top Loading Washer
Frigidaire LA625EXW3 Wwh(v20) / Top Loading Washer
Frigidaire LA625JXD3 Wwh(v6) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXD4 Wwh(v11) / Top Load Washer
Frigidaire LA625JXD5 Wwh(v5) / Top Load Washer
Frigidaire LA625JXF3 Wwh(v7) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXF4 Wwh(v12) / Top Load Washer
Frigidaire LA625JXH3 Wwh(v8) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXH4 Wwh(v13) / Top Load Washer
Frigidaire LA625JXV3 Wwh(v9) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXV4 Wwh(v14) / Top Load Washer
Frigidaire LA625JXW3 Wwh(v10) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXW4 Wwh(v15) / Top Load Washer
Frigidaire LA625JXW5 Wwh(v6) / Top Load Washer
Frigidaire LA625MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA625MXW1 Wwh(v3) / 27 " Washer
Whirlpool LA6300XPW0
Whirlpool LA6300XPW1
Whirlpool LA6300XPW2
Whirlpool LA6300XPW3
Whirlpool LA6300XPW4
Whirlpool LA6300XPW5
Whirlpool LA6300XPW6
Whirlpool LA6300XPW7
Whirlpool LA6300XSW0
Whirlpool LA6300XSW1
Whirlpool LA6300XTF0
Whirlpool LA6300XTF1
Whirlpool LA6300XTG0
Whirlpool LA6300XTG1
Whirlpool LA6300XTM0
Whirlpool LA6300XTM1
Whirlpool LA6300XTN0
Whirlpool LA6300XTN1
Whirlpool LA6300XTW0
Whirlpool LA6300XTW1
Whirlpool LA6301XSW0
Whirlpool LA6380XPW0
Whirlpool LA6380XPW1
Whirlpool LA6380XSW0
Whirlpool LA6400XKW0 Washers*
Whirlpool LA6400XPW0 Washers*
Whirlpool LA6400XPW1 Washers*
Whirlpool LA6400XPW3 Washers*
Whirlpool LA6400XPW4 Washers*
Whirlpool LA6400XPW5 Washers*
Whirlpool LA6400XPW6 Washers*
Frigidaire LA640AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA640AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA640AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA640AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA640JXD3 Wwh(v1) / Top Loading Automatic Agitator Washer
Frigidaire LA640JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA640JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA640JXW3 Wwh(v2) / Top Loading Automatic Agitator Washer
Frigidaire LA640JXW4 Wwh(v2) / Top Load Washer
Frigidaire LA640JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA640MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA640MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA640MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA6500XPW0 Washers*
Whirlpool LA6500XPW1 Washers*
Whirlpool LA6500XPW2 Washers*
Whirlpool LA6500XPW4 Washers*
Whirlpool LA6500XPW5 Washers*
Whirlpool LA6500XPW6 Washers*
Whirlpool LA6500XSW0 Washers*
Frigidaire LA650AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA650AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA650AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA650AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA650AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA650AXW3 Wwh(v2) / 27 " Washer
Frigidaire LA650EXD3 Wwh(v1) / Washer
Frigidaire LA650EXF3 Wwh(v2) / Washer
Frigidaire LA650EXH3 Wwh(v3) / Washer
Frigidaire LA650EXV3 Wwh(v4) / Washer
Frigidaire LA650EXW3 Wwh(v5) / Washer
Frigidaire LA650JXD3 Wwh(v11) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXD4 Wwh(v3) / Top Load Washer
Frigidaire LA650JXD5 Wwh(v4) / Top Load Washer
Frigidaire LA650JXF3 Wwh(v12) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXF4 Wwh(v4) / Top Load Washer
Frigidaire LA650JXH3 Wwh(v13) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXH4 Wwh(v5) / Top Load Washer
Frigidaire LA650JXH5 Wwh(v5) / Top Load Washer
Frigidaire LA650JXV3 Wwh(v14) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXV4 Wwh(v6) / Top Load Washer
Frigidaire LA650JXW3 Wwh(v15) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXW4 Wwh(v7) / Top Load Washer
Frigidaire LA650JXW5 Wwh(v6) / Top Load Washer
Frigidaire LA650MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA650MXW1 Wwh(v3) / 27 " Washer
Whirlpool LA6680XPW0
Whirlpool LA6680XPW1
Whirlpool LA6680XSW0
Whirlpool LA6700XKW0
Whirlpool LA6700XKW1
Whirlpool LA6700XKW2
Whirlpool LA6700XMW0
  #2 (permalink)
Old 11-29-2010, 11:49 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Part number: AP4026340
Click on the above for more info.
If it looks physically OK, no cracks etc. it is probably OK.
You would have had more of a clue as to what is going on if you had tried unplugging it or turning it off first.
If you unplug the unit and water continues to run then the water valve is stuck open and needs replacing.
If you can stop it by turning the unit to off then the water level switch or it's hose are the most probable cause.
Switch checks:
1. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it.
2. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard.
If you cannot stop it the switch is toast.
__________________
  #3 (permalink)
Old 11-29-2010, 12:27 PM
Junior Member
Default
thanks very much. I'm going to order this hose and the water valve and see if that does the trick.
Regards, Tom
  #4 (permalink)
Old 11-29-2010, 03:12 PM
Senior Expert
APP Volunteer
Default
I think I would try blowing into the water level switch with a piece of tubing before ordering any thing.
If you can stop the water flow then you know the water valve is OK and odds are that the water level switch is also OK.
Then it just leaves the tubing.
__________________
  #5 (permalink)
Old 11-29-2010, 03:58 PM
Junior Member
Default
Thanks; I'll do that. The washing machine is at a different house, so I can't do anything more for probably a couple of weeks. I'll follow the steps you have recommended to get to the bottom of the problem -- hopefully it will be an easy fix. Thanks again, Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer Tania Corkery Washer Repair 1 01-02-2010 06:17 PM
maytag washer douglas petzoldt Washer Repair 5 08-07-2009 04:59 PM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
maytag washer Tracy Ahana Washer Repair 1 03-24-2008 05:47 PM
