| » Removing Transmission/Motor Assembly |
Model Number: KAWE660WWH3 Brand: Kitchen Aid Age: More than 10 years
It appears that the Direct Drive Coupling has failed. I'm trying to remove the transmission and motor to verify that that is the only problem. I've removed the three bolts holding the trans to the tub support, and I've removed all the hoses. I just can't work the trans loose from washer. Is there something else that I need to do?
| Display Modes | |
| is it motor or transmission | kip dean | Washer Repair | 0 | 05-07-2010 11:30 AM |
| Transmission assembly replacement | LBarker | Washer Repair | 1 | 01-28-2010 05:03 PM |
| Removing bottom wash assembly | Lance W | Dishwasher Repair | 2 | 08-22-2009 08:02 PM |
| can't re-lift transmission/clutch assembly | Chrispy0818 | Washer Repair | 0 | 11-17-2008 06:47 PM |
| Removing pump motor assembly | dcherioke1 | Dishwasher Repair | 1 | 09-14-2007 10:50 AM |
