I have a washer that will spin and drain, but will Not Fill or Agitate. I tested the water inlet valve with an Ohm meter and got a reading of 1084 on cold and 1079 on hot. Is this normal? If this is not the problem, what else could it be? Thanks! -Chuck
THIS FORUM IS DEAD!!!!!!! |
