Discuss
Washer won't spin
 in
Washer Repair
My washer fills, agitates, drains, but won't spin; motor hums, but drum will not spin; any advise? Ads By Google
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't spin
  #1 (permalink)
Old 11-28-2010, 02:20 PM
Junior Member
lmarion is on a distinguished road
Default Washer won't spin
Brand: Estate   Age: 5 - 10 years
Ads By Google
  #2 (permalink)
Old 11-28-2010, 06:40 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Probably a Whirlpool machine...but we need a model number. Please look in the front of the machine, just under the motor (it's right up front, in the middle) and see if there is any debris of white plastic or black rubber on the floor.
If there is, That's a sign you need to replace the motor coupler.
Part number: AP3963893
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
washer does not spin, fills up and drain the water nornal but do not spin leaderman Washer Repair 0 10-04-2010 02:28 PM
washer makes grinding noise and won't spin on spin cycle marine1969 Washer Repair 1 08-30-2010 07:19 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
