| » No drain BEFORE spin |
Model Number: 110.23832100 Brand: Kenmore Age: 1 - 5 years
Not draining after wash cycle but timer continues w/o noise from machine (pump not draining prior to spin). Starts slowly spinning with water in tub and starts draining (pumping) too but not enough water out by end of cycle to spin fast enough. If set to beginning of spin cycle 2 or 3 times water is finaly pumped out and spins "dry" but repeats same process in rinse/spin cycles. What's going on here?
Make sure the drain hose isn't jammed into the stand pipe; there needs to be a slight air gap. Look for a clogged or kinked drain hose. If these things check out OK, you may have a clogged pump.
| Display Modes | |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works | cosmo99 | Washer Repair | 1 | 01-27-2010 11:33 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| does not drain or spin | beezly | Washer Repair | 2 | 11-03-2008 12:05 PM |
