| » timer wiring problems |
Model Number: LSR7233BW1 Brand: Whirlpool Age: More than 10 years
On regular cycle, the washer will go through all cycles except the final spin. Spin works on Perm. Press and Delicate.
If I rock the timer knob downwards to the right (see attached photo), the spin works, but I have to hold it in that twisted/rocked position to keep the spin running. I replaced the timer, and have exactly the same problem with the new timer. Wiring - the ground from the cabinet to the control panel tests ok for continuity, the ground from the cabinet to the timer mounting screws test ok for continuity, and the ground from the cabinet to the back of the timer switch tests ok for continuity. I don't see any damaged or exposed wires, and can't find a short in the grounding. Looking for suggestions on what to check next. Ads By Google Related Models |
| Display Modes | |
| wiring for timer dryer | getbetterlater | Dryer Repair | 8 | 07-30-2012 02:24 AM |
| timer wiring | justn1978 | Dryer Repair | 2 | 07-20-2010 08:13 PM |
| GE DBXR453ET3WW timer wiring help | Snowboarder81 | Dryer Repair | 1 | 12-18-2009 11:43 AM |
| Wiring Diagram for Timer | Jackof Altrade | Dryer Repair | 3 | 05-30-2009 01:17 PM |
| Timer wiring | novelistwendy | Dryer Repair | 1 | 02-04-2008 02:53 AM |
