| » kenmorre washer leaks on spin cycle only |
Model Number: 110.92293100 Brand: Kenmore Age: More than 10 years
My kenmore top loading washer has developed a leak somewhere.. during the spin cycle only... during the first drain & refill for rinse there is no water but late in the spin cycle I see some water oozing out from under the unit. I took the cabinet off the frame to check the hoses and found that there is water marks on the inside of the cabinet almost completely to the top and I also found a little water trail on the outide of the washer from the space between the top portion of the cabinet (the part where the lid is attached ) and the bottom cabinet. Any thoughts on what is really happening.
Thanx Dan Ads By Google Related Models |
So I ran the rinse and spin with no leakage. So Now I am wondering if maybe there might be a leak in one of the hoses that feeds the bleach/softener trays and this leak put enough water on the lip that surrounds the basket/tub it is about 2 inches wide and is like a trough. And then when the washer goes into spin mode the vibration throws the water around.
Dan |
The water is generally on the left side (the side with the bleach / fabric softener dispenser) there is a small space (1/64th of an inch) between the base cabinet and the lid assembly where this bleach / fabric softener dispenser is mounted and there are hoses running along this side under this lid assembly.
Dan |
| Display Modes | |
| Speed Queen washer leaks during spin cycle | LeakyWasher | Washer Repair | 4 | 12-10-2012 12:23 PM |
| Washer leaks and terrible noise at spin cycle.. | cskadavil | Washer Repair | 28 | 11-03-2009 04:40 AM |
| washer leaks during spin cycle | harryupson | Washer Repair | 1 | 10-04-2009 08:45 PM |
| Kenmore Series 80- leaks in spin/empty cycle | pbouv2 | Washer Repair | 2 | 07-28-2009 07:18 PM |
| leaks a LOT on spin cycle | ldmoff123 | Washer Repair | 12 | 09-13-2008 07:58 AM |
