| » Kenmore Washer noisey on brake |
Model Number: 110.20892990 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore 80 series washer machine that when it finshes a cycle and is changing it makes a horrible racket. I think its trying to stop the spinning drum like brakes engaging. I have taking it all apart a few times thinking that loud of a noise has to be very easy to find? but nothing looks broken or loose? Any Help?
If the spin basket is not loose, I would pull the pump and motor off and turn the tranny coupler clockwise till it engages spin. As you turn the coupler, the basket should spin. If you feel any roughness you have a bad transmission internal nylon gear, just pull tranny to verify.
__________________
Thanks for the reply, Im pretty sure I took the trans apart and didn't see any plastic gears? How do you know if the basket is loose? I think it may be up there? When I put it back together it's better for a a couple washes then it starts getting worse?
Remove the agitator and check the drive block nut, probably loose. Pull the spin basket out and check the spin tube tabs, might be worn. If ok, use the spanner wrench AP3538707 to tighten the nut, gotta be real tight to prevent problems.
__________________
I have changed that block before because it was worn out. About 2 years ago, I thought that was my problem as well a few times but it looked ok and I changed it anyways. I dont have a spanner wrench to tighten it so I use a long flat punch and a hammer. I think I get it as tight as I could with any spanner wrench. Those tabs were bent and rounded?I straighten then and filed them square again the first time I took it apart. Like I said when I put it back together its quite for a couple washes then starts getting louded again. I think its up in that area as well but dont know how to locate the problem?
Unfortunately, you might need a new spin tube on that, the chewed up tabs may have damaged the drive block. Really hard to get that nut on tight without the spanner wrench.
__________________
| Display Modes | |
| Kenmore 80 Series Washer Loud Noise and will not Brake | rbouchard1 | Washer Repair | 0 | 02-23-2009 01:59 PM |
| brake on atlantis washer | mteal | Washer Repair | 0 | 01-25-2009 06:33 AM |
| Kenmore Series 90 Plus 110.28942890 brake issue?? | les.warden | Washer Repair | 12 | 01-06-2009 05:30 AM |
| GE Washer brake | scald | Washer Repair | 9 | 11-14-2008 04:56 AM |
| Noisey washer | Harv664 | Washer Repair | 0 | 09-29-2008 09:25 AM |
