Discuss
Whirlpool brake or clutch issue
 in
Washer Repair
My washer started making a loud WHUMP-WHUMP-WHUMP-WHUMP when the brake is engaged (after each spin cycle). It does it the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool brake or clutch issue
  #1 (permalink)
Old 11-13-2008, 07:58 AM
Junior Member
mtreu is on a distinguished road
Default Whirlpool brake or clutch issue
Model Number: LSN2000JQ1   Brand: Whirlpool   Age: 5 - 10 years
My washer started making a loud WHUMP-WHUMP-WHUMP-WHUMP when the brake is engaged (after each spin cycle). It does it the entire time the drum is slowing down and only while it is trying to brake.
I did some reading and some suggested changing the drive block. I bought the drive block and was thwarted in trying to get the original one off without the special tool - so I gave in and called a repair person. He played around a bit and ascertained that the issue was not the drive block, and instead was either the clutch or the brake.
He charged $80 and said it would be another trip and ton of money to fix it. He then said that he believed me to have the know how to change the brake/clutch myself.
I took it apart, expecting to see something physically broke and save having to change the whole thing. I took everything apart, and could not see ANYTHING physically broke with either the clutch or the brake. I next took the brake completely apart, and put it back together again. Hand testing, it appeared to work fine. I put the whole washer back together again, and viola the problem went away... for about four loads of laundry.
I once again have ripped it apart and it AGAIN looks fine. My first thought was brake shoes ($20). I have a hard time with this, as they look fine to me. The calipers, do not look bent or damaged and the pads do not look excessively work when compared to pictures on-line. Thus, I sincerely don't believe the issue to be the shoes. I was toying with the idea of changing the entire brake ($80), which I don't want to do if it is overkill - and I believe I have to remove the drive block to change the entire brake (again, I do not have that goofy tool, and banging it with a screwdriver does not work!).
Can anyone shed any light on this?
Brake shoes?
Entire brake?
If I need to change the entire brake, does the drive block need to be removed?
Thanks – this site is a godsend!!
-hj
Ads By Google
Related Models
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
  #2 (permalink)
Old 11-13-2008, 02:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How it spins? If it does it good and the problem is just a noise when it's trying to brake, I would spray WD-40 on the brakes.
Here are the break down diagrams for the Whirlpool washer Model LSN2000JQ1
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-13-2008, 02:45 PM
Junior Member
The noise is very loud. Not something that sounds like WD-40 would fix. Also, when it makes the noise, the brakes do not seem to be working as they should - the drum takes longer than usual to slow down (about 7-10 seconds).
When the clutch is supposed to activate the brake, it looks like it is supposed to rotate the oblong metal block about a half turn, thus activate the brake. Could something be wrong in that it's moving the oblong block into position but it isn't locking in the brake position - and instead is rotating the block which would cause the brake to engaging and disengage, making the WHUMP-WHUMP-WHUMP noise?
Would this be a sign of transmission then instead of brake/clutch?
Thanks for the reply!
  #4 (permalink)
Old 11-13-2008, 05:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Why you would not try WD-40 first and then report the result?
You would like to save money and I'm trying to do the same for you.
__________________
  #5 (permalink)
Old 11-13-2008, 06:21 PM
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
You're going to need a new basket drive or spin tube is another term for it the new spin tube will come with the shoes for the clutch and istuctions what spring to use They never do show wear unless your eye is trained to see it ......the bad thing you'll still need the spanner wrench
__________________
  #6 (permalink)
Old 11-14-2008, 03:49 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
I would buy the spanner wrench, remove the agitator and spin basket and inspect the tabs on the end of the spin tube. If worn, you need a new spin tube.
__________________
  #7 (permalink)
Old 11-19-2008, 04:57 PM
Junior Member
Gene - not diss'in you. I was offering more information that I may have neglected to mention. Wanted to see if you still believed WD-40 would fix it - no disrespect meant. My wife was hawking me to get it back together again, so I tried WD-40 while putting it back together. It unfortunately didn't help.
I am going to see if I can get a wrench from someone to save me $35.
Thanks again for the advice all you guys! I will investigate the spin tube idea.
Man - dropping on a new washer after only 6 years would be miserable! I've fixed washers and dryers before, I can fix this. Proof... I know what a wig-wag is.
Thanks again guys!
  #8 (permalink)
Old 11-19-2008, 10:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
At this point I agree with Richappy and v2k04. The new spin tube with new brake shoes and probably the new drive block should solve the problem.
I could not guarantee WD-40 will fix it, but it was worth a try because it did work for me a few times with a similar problems and that's why I did recommend it.
Good luck and Happy Thanksgiving.
__________________
  #9 (permalink)
Old 11-21-2008, 02:30 AM
Senior Expert
APP Volunteer
Default
Put in the search box, "replacing direct drive brake shoes" and do the test in there.
If turning the coupler produces a rough spot, you may have a bad nylon gear in the tranny.
__________________
  #10 (permalink)
Old 12-02-2008, 06:49 PM
Junior Member
Default same
I finagled a spanner wrench to check the drive block. Rookie question - when I turn the spanner wrench it turns the entire basket. How do I lock the basket in place so I can really reef on the nut on the drive block to loosen it?
and...
richappy - I unfortunately believe you might be right about the transmission plastic. I entered "replacing direct drive brake shoes" in the search to see the post you are referring to, and it bring up several posts that really don't sound related. Can you be more specific on the post?
After I get the nut off...
1) I'm going to change the drive block, since I already bought one before this expedition.
2) If that doesn't fix it, and the spin tube teeth look okay, I am going to have to believe that you are correct.
If I stop the spin cycle that is making the thump thump thump noises, I can manually turn the drum and feel/hear it "catch", as you are referring to.
Someone tell me how to lock the tub and I'm on to the next step!!!
Thanks a million all of you! If you need a computer or arcade game fixed, let me know - I owe you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing the clutch on a Whirlpool washer boselam Washer Repair 12 09-28-2011 07:16 PM
Clutch/Brake band replacement bigtandt Washer Repair 2 02-12-2010 08:18 AM
Brake on whirlpool washer mechanic Washer Repair 8 11-02-2009 01:33 AM
Kenmore Series 90 Plus 110.28942890 brake issue?? les.warden Washer Repair 12 01-06-2009 05:30 AM
Whirlpool Clutch Replacement bermudabye Washer Repair 1 01-07-2008 07:19 AM
